Question about Mintek MDP-1070
When trying to play dvd, it stuck on loading and it won't play the dvd.
  • Mintek Master
  • 16,387 Answers
This might be a lot of things. THE first thing that you need to do is try several disks. If you get the same error on all of them EVEN CD's then you have to check and see if the head is moving and if the laser is clean. You should be able to do this when you open the unit. THe head and the laser should be visible if the lid for loading pops up. The other kind that you have to insert the cd in is more difficult to work with,.. ANyway you can move the head toward the outter area. (CD and DVD play from the inside out). Then you try again and see if the head is moving. If it is then you have an issue with the laser. You can clean it with a q-tip and alcohol. Then try it again. IF this wont work then it is time to see about a new one. NOTE that it can play CD's and not movies as there are two lasers in the unit.
Posted on Oct 17, 2010
Won`t play dvd`s.try a cleaning disc no luck!possible dvd diode gone?any help please.Nigel...
Hi Nigel,
There are three reasons for discs not playing.
First, if the set has been lying for some time, the loading belt becomes lose and the loading is not complete. The result is no disc play.
Second, there is dust on the lense. Again the result is no disc play.
Third, the lense unit has gone bad or weak. Here also the result is no disc play.
Jan 24, 2016 | Televison & Video
Life of Pi blu ray won't start up. Plays 20th Fox Logo o.k. but won't start up
I have the same problem, tried it on 2 different (functioning) blu-ray players at home with the same result. Both are up to date with latest firmware but will not play this disc. Finally had to just watch the standard-def DVD version until I can solve this.
Mar 13, 2013 | Televison & Video
DVD JUST LOADS WON'T PLAY
Try cleaning the lens of your DVD player either by a lens cleaning CD or remove the dvd cover and clean the lens using a soft cotton bud dipped in Shaving lotion or Lens cleaning liquid.
Oct 27, 2012 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
DvD disc won play
the lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Jul 06, 2010 | Onkyo DV-SP800 DVD Player
My DVD player stays stuck on loading. How can I
If all DVD's you try act the same, I would clean the read head. If that doesn't work, then drive needs to be serviced. Hopefully nobody smked cigarettes near the unit as that coats the optics. Clean the read head VERY carefully with a Q tip and 99% isoprophyl alcohol. Ensure that no fibers get stuck around the read head... it is VERY fragile.
If only one disk won't finish loading, then the disk itself is probably bad and the drive is OK.
Jan 03, 2010 | Samsung DVD-V5500 DVD Player/VCR
Axion dvd player 6070A 7 inch screen stuck on loading
not good, the unit will cost more to fix than replace. The only thing that might help is if it has a removable battery, if so take it out and leave it out for an hour, & try again. You might try using the power cord instead( I dont think it will help but try it before you toss it out)
Jul 11, 2009 | Axion AXN-6070A 7 in. Portable DVD Player...
Some normal DVD's will not play--as if not loaded.
try using a lens cleaner.....normally its a lens issue....should work better after cleaning...
May 17, 2009 | Sony SLV-D300P DVD Player/VCR
Mintek MDP-1070 Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
