Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Where do I connect the water hose in the back for the refridgerator
    Sergeant:
    Champion:
  • 226 Answers
What kind of water hose.this ice maker should fit 3/8 cut off value and sit in the back at the bottom
Posted on Oct 16, 2010
Water leaks
Need more information
Does the refridgerator have plumbing for water/ ice? Is the water connected? Check that fittings are tight and not leaking.
How old is your machine? Older refridgerator have a drip pan in order to be frost free. Drip pan could be not in correctly or the hose from compressor is not flowing to drip pan.
Is the refridge level?
Oct 15, 2015 | Whirlpool Refrigerators
LEAKING WATER
The plastic line has cracked at the water valve. See this page item 804:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=206380&diagram_id=21040526#d21040526
It is a matter of turning off the water supply, removing the attaching nut and compression fitting then cut off the line... transfer the inner sleeve nut and brass outer compression ring to the new hose then reinstall the line onto the water valve. If it is leaking at a water filter connection the repair is the same as above.
Turn on the water supply when you finish.
Thanks for using FixYa.
Kelly
May 12, 2010 | Refrigerators
Water is dripping inside refridgerator coming from inside back center. Why? Sometimes it drips, sometimes it runs and sometimes it's fine.
Is water connected to this unit for the ice maker? If not than this would be the water that comes off the refrigeration coils as the unit defrosts. The water should be collected by a shallow plastic collector, routed to a drain tube, and empties to a pan under the frig where the water will evaporate quickly. Check drain collector for damage and drain hose for blockage.
Mar 31, 2010 | Whirlpool Refrigerators
How to replace an icemaker hose
Turn water off from the supply. There should be a valve that the 1/4" water line connects to, if not you will have to shut off the water main. Using a wrench remove the nut from the water line connection (usually a compression fitting. You will need a need compression sleeve with the new line x2, one for the valve and one for the fridge. Next disconnect the line from the back of the fridge. Run the new line the same way the old one was run, for easiness. Make sure you leave enough slack behind the refridgerator to allow it to be pulled out and cleaned behind. Once all connections are tight you can turn the water back on and ensure you don't have any leaks. Hope this helps.
Mar 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
There is water in the refridgerator
You have a disconnected defrost drain pan. You will need inspect the ceiling of your refrigerator compartment and find the drain hose going from your freezer to your fridge then the drain pan. Sometimes this is molded into the plastic at the back of your fridge and it simply leaking out the joint. Start by defrosting your freezer, then pour water in the freezer itself while checking the ceiling of the fridge for water traces. Keep a wet/dry shop vac handy or a mop to keep up with the excess drainage. Then reattach the hose to the little drain nozzle when you find it.
Mar 13, 2010 | SUMMIT Professional FF1615SS Refrigerator
Why do i have water in my refridgerator
Air contains water particles and it will condense to form solid ic, you have to defrost your refridgerator on a regular basis and have to watch the water is drained up to the maximum extent
Dec 17, 2009 | Kenmore Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Refrigerator drain hose disconnected.
the back of the refridgerator should have a panel you can remove at the bottom (Make sure to turn power off first). After removed you should see a hard plastic white hose coming from you freezer. If off you should be able to slide back over to connect.
Mar 28, 2009 | GE Profile PSS26NGS Side by Side...
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Hello? I have a new Eclipse Kenmore being installed Tuesday 12/23. What do I need to provide for a water supply?
I see your installation date has come and gone, but if you still need to hook up the water you can find an "ice-maker kit" from almost any home improvement store (such as Lowes, Ace, Home Depot etc....) This includes 1/4" bendable copper tubing and a valve that will tap a near by cold water supply pipe. If you find a kit with plastic tubing, I would steer clear and find the bendable copper. Plastic tubing kits are notorious for springing leaks. Buy some extra compression nuts and washers for the tubing while you are there, it may take more than one try to get a waterproof seal if this is your first time hooking up water and ice dispenser.
When hooking up the tubing to the back of the refridgerator, leave a couple coils of slack to allow the refridgerator to be pushed in or pulled out without straining the connection. There is usually a small clamp on the refridgerator back to hold the tubing steady, make sure you use this. This will help ensure a leak free connection. After you have the tube hooked up, push the refridgerator all the way back, then pull it back out and check for leaks. Sometimes the tube will start dripping a bit after the refridgerator is moved, so this step helps ensure you won't have leak problems.
Dec 22, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
