Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I am having a problem with the transmission being hard to change gears. It's so hard that I broke a gear shift lever. I got that replaced but it is still hard to shift. I just removed the transaxle and the tang that the shift linkage connects to is still in place. You cannot shift it with you bare hand. Do I need to go inside the transaxle? Maybe gunck inside? I just don't know. Looking for suggestions!
  • Buddy wommack Oct 20, 2010
    Thanks...The clutch seems fine, no problem there. You just have to use both hands to get the gear lever to move. It finally will, but I am afraid I am going to break another shifter. There are only two little screws that hold it onto the linkage. Not a very good design. That is where it broke last time. By the way, as I said, I have the transaxle out and the shfter tang on the transaxle is hard to move. Shouldn't it just click into gear?
    Hey you are preaching to the choir on that one. I have a Ford F150 that I use Slick 50 in with every oil change. I make that change every 5K miles and it now has 375K miles on it. Still runs like new. No oil usage...still plenty of power. I will give that a try in the transaxle and see if it makes it shift any easier. Thanks!
  • 2,299 Answers
There are two things that you can do to solve this problem. Oil all of the pivoting points in the linkage. Make sure the linkage is all straight. And change the gear oil in the trans-axle. Another thing that you can check is make sure that the clutch is engaging all the way. You can do this by when you put the tractor in gear it doesn't move or roll. If it is rolling when you have the clutch in then adjust the clutch also.
Posted on Oct 20, 2010
  • Rodney Clark
    Rodney Clark Oct 20, 2010
    Yes. It should click into gear pretty easy with the trans-axle out. The shifting fork inside could be bent. Something that I use in everything now is Slick 50. You can add some of that to the trans-axle. My wife drove her car about 50 miles after the oil filter had came off, after changing the oil. I didn't get it tight, got side tracked. But I had Slick 50 in it and we still drive the truck today. That made a believer out of me. Maybe it would loosen up the shifting.
  • Rodney Clark
    I hope that it works out for you! Good Luck!
Wont go in 2nd gear
If it will go into all other gears but not second, the transmission may have damage like a bent shift fork, damaged gears and/or shift drum. If the bike has been raced or accelerated hard and gear shifts have been missed, it most likely has transmission damage and the engine will have to come out and be torn down in order to repair. If the bike was hopping in and out of second gear before it stopped going into second, the transmission is most likely damaged.
One more thing to try is to take the shift lever and push momentarily down or up on the lever and see if it smoothly returns to its original center position. If it does return to the center position the lever is not sticking and ir it does not return to center position then the shift lever is sticking and that will keep the trans from up or down shifting.
Feb 20, 2013 | 2006 Suzuki GSX 1300 R Hayabusa
2003 chevy suburban 4wd 1500 lt shifts slow to 2nd gear and vibrates between 65 and 70 mph
Sounds to me that you need your trans fluid changed and filter. When you do change it use a quart of Lucas transmission conditioner to it. Also check and see if you may have a bad univercel, It will also make it vibrate at faster speeds or your drive shaft may need to be rebalanced.
Nov 25, 2012 | Chevrolet Suburban 1500 Cars & Trucks
Renault trafic 100 dci gear selector
There are few related help links related to gear shift issues:----
Click the link below:----
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode? http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Transmission in chevy silverado 1500 5.3L v8 will not shift from 2-3 gear transmission has been rebuilt and 2-3 shift solenoid was changed but still will not shift from 2-3 gear
For gear shift issues and gear stuck issues,the help links are provided below. Click the link below to go through troubleshooting procedure:---- ---- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ---- transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ----- Transmission not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ----- Vehicle only goes in First gear?
---- Engine will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html ---- Car stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html ----- Car will not come out of Park?
--- Car wont downshift sometimes?
---- Transmission will shift into drive?
----- Auto wont shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html ---- Car Transmission will not go into Park mode?
----- Shift indicator directly goes to 2nd when key is turned ON?
---- Third gear missing and engine losing power?
------- Vehicle has whining sound in gear?
----- Hard to shift gears on Manual transmission?
------ Car hard shift at slow speeds?
--- Automatic transmission shift lever hard to move on cold mornings?
------ Gear shifts hard?
------- Vehicle noticed sluggish delayed shifts while driving?
This will help.
Thanks.
Mar 14, 2012 | 1999 Chevrolet Silverado 1500
My old falcon will not shift into gear will go into park but when shift lever is moved car will not go into gear
This will help.
Thanks.
Mar 11, 2012 | 1996 Ford Explorer
Why is my car stuck in fifth gear?
For gear shift issues and gear stuck issues,the help links are provided below.Click the link below to go through troubleshooting procedure:--------Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html----transmission sticks in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html-----Transmission not engaging in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html-----Vehicle only goes in First gear?
----Engine will not go out of park mode?http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html----Car stuck in park?http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html-----Car will not come out of Park?
---Car wont downshift sometimes?
----Transmission will shift into drive?
-----Auto wont shift from park?http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html----Car Transmission will not go into Park mode?
-----Shift indicator directly goes to 2nd when key is turned ON?
----Third gear missing and engine losing power?
-------Vehicle has whining sound in gear?
-----Hard to shift gears on Manual transmission?
------Car hard shift at slow speeds?
---Automatic transmission shift lever hard to move on cold mornings?
------Gear shifts hard?
-------Vehicle noticed sluggish delayed shifts while driving?
This will help.
Thanks.
Mar 05, 2012 | Cars & Trucks
Manual transmission
This will help.
Thanks.
Feb 29, 2012 | 2004 Ford Focus
1993 mercedes benz 400E wont shift into 3rd gear
This will help.
Thanks.
Feb 12, 2012 | RTO Automatic Transmission And Engine Oil...
My 1993 Gmc Sierra 2500 automatic first gear shifts hard also from park to drive others gears are smooth i have overdrive
The gear shift lever indicators tell you what gear you have an automatic transmission in on your vehicle. The shift solenoid tells the transmission when to shift gears and what gear to shift into. Newer model automatic transmissions have electronic shift solenoids that are activated and change gears based on the speed the vehicle is traveling. Troubleshooting either one of these transmission components is relatively easy if you know a little about automobile mechanics. With the right tools, you can determine whether the transmission shift solenoid is having a problem. Gear shift indicator problems can be determined simply by moving the gears into their designated position.
Transmission Shift Solenoid
  • 1 Raise each corner of the vehicle up with the car jack and place jack stands under the frame. Make sure the car is raised high enough so you can work under the car freely.
  • 2 Slide the drain pan under the transmission fluid drain plug. Remove the drain plug with a ratchet and socket, and let all the fluid drain out of the transmission. Remove the transmission pan bolts with a ratchet and socket. Pull the pan away from the bottom of the transmission, revealing the transmission shift solenoid.
  • 3 Wipe off the shift solenoid with a shop towel. Disconnect one of the two plugs that attaches to the shift solenoid. Turn the knob on the volt meter to the ohms setting, so resistance can be measured. Set the volt meter on 200.
  • 4 Take the black lead of the volt meter and touch the negative battery terminal wire. Take the red lead of volt meter and slide the tip into the terminal plug you just disconnected from the shift solenoid. Look at the reading you get on the digital display of your volt meter. Determine if the reading is between 12 and 25. Readings below 12 or above 25 tell you that the shift solenoid is not working. Reattach the plug to the shift solenoid and pull the second plug attached to the solenoid. Perform the same procedures on this plug wire. Replace the transmission shift solenoid after determining it is bad.
Gear Shift Indicator
  • 1 Move the gear shift into the desired gear. Look at the gear labels and the arrow, or other indicator, to see if the gear shift indicator lines up with the selected gear.
  • 2 Move the gear lever to another gear and look to see if the indicator lines up with the selected gear. Misalignment of the arrow will tell you if there is a problem. Moving the gear shift to "neutral" but having the indicator show the transmission is in "drive" tells you the gear shift indicator is not working properly.
  • 3 Try each gear position to determine how much misalignment is in the indicator. Slide under the car and check for a loose gear shift cable. Check all the gear shift cable connections to ensure they are all tight and are not missing. Tighten any loose gear shift cable clamps or bolts. Replace the gear shift cable if you find that this is causing the misalignment with the gear shift indicator.
Feb 02, 2012 | 1993 GMC Sierra
Chevrolet Automatic express 2500 gear shifter is broke, what are the parts for the shifter and from shifter to the transmission?
gear shift selector roll pin that holds shift lever in postion shift rod shift rod pivot and spring assembly, colomm retainer assembly pin for shift lever lower and shift linkage lower.
Sep 10, 2009 | 2002 Chevrolet Express
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
113 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
