Question about Kenmore HE2 Plus Front Load Washer
It said SD...What does that mean and what should we do about it? Thank you.
  • Kenmore Master
  • 8,220 Answers
Suds detect. Very bad! Too much soap! The idea behind the operation of this washer is to accomplish 2 basic things: Water and energy saving. They do it by continuously recirculating a tiny amount of water and using a tad of soap. If you go adding in more than specified then the brains of the tang goes haywire. To get the clothes washed with that tiny amount of water Brainiacs needed to invent a soap that makes less suds so that the tiny amount of water does not cause residue from soap to cling to your clothes. hay I ain't makin this up. There have been study's done in the US. Looks like you are gonna have to perform an operation similar to this guys solution:
Posted on Oct 17, 2010
  • Dan Webster
    Dan Webster Oct 17, 2010
    You can try this:
I have an "Sd" code on my Model# LGEF3045KFC stove after an electrical storm, what does that mean?
Good afternoon friend, thank you for your post!
I see you are having trouble with your Frigidaire range and you are receiving error code "Sd". However, it appears "Sd" is an invalid error code. It is possible that the error code is missing characters?
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "Sd". I look forward to assisting you. -Matt
Sep 03, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
SD card
It has a slot on the outside of the unit for a SD (SD=Secure Digital) card, SD is a small square card for storing information, a mini solid state hard drive is what it is closest to. Goggle SD card and see the pictures.
May 17, 2012 | Magellan Roadmate 760 GPS Receiver
Kenmore front load hasher model @110.47512600 has error codes ---5d and f33--whats wrong?
Hello, Thank You for using FixYa. I will be helping you today. SD means suds detected as in too much soap or not using HE detergent. Try to do a rinse spin cycle. F33 is lost connection between pump and ccu,May be related to the suds issue.
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Washing Machines
My nokia7210 supernova does not open music player and video player when i open music player its shows me not enough memory....;pls help me..........
Welcome to FixYa!
To have more storage capacity for your phone, delete unimportant SMS in your INBOX, OUTBOX and SENT ITEMS. Delete also unimportant pictures, videos, music and ringtones. The phone memory is relatively small and is shared to all data and other files that are stored in the phone. By deleting some of these will free you some memory.
Alternatively, you can also put in a Micro SD memory card(Memory Card model depends to what your cell phone is compatible of, Micro SD is a sample) to your phone which will also increase its storage capacity. A Micro SD Card look something like the picture below.
A 16GB Micro SD is available at AMAZON http://astore.amazon.com/doityousol-20/detail/B001L1H0SC
Thank you for using FixYa.
Have a great day.
Jas247
Jun 03, 2011 | Nokia 7210
The power light on my panasonic PT-53TW53 blinks 5 times in intervals. The TV set does not turn "on". Could you advise what this means ? Thank you for your help.
5 BLINKS means a short on the 140 volt line inside the set.
Usually this means the horizontal output transistor is shorted.
I can if you are able how to test for this and what to look for that may have caused this.
I am in California and online right now.
SD TECH
Feb 11, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Memory card not supported by mobile nokia 3110
hi
this phone has the facility of supporting the micro SD memory up to 2gb only.make sure that your memory card is within this limit.if so check that the card is working another phone.these problems are due to card or by phone.if problem is not in card means just restart the phone and try it.if still same problem means just try it after formatting the phone.still having problem means you can contact your mobile service
thank you
Dec 17, 2010 | Nokia 3110 Cellular Phone
I put an 8GB microsd card (with an microSD to SD adapter) in may Pentax OptioX and when I open my camera, I have a short delay, then I receive an 'Memory card error'. What's the problem? Thank you.
The S5i uses SD cards. This means you can use microSD cards with an adapter. However, your 8GB card is actually a microSDHC card, which with the adapter appears to the camera as an SDHC card. SDHC cards are electronically incompatible with SD devices and will not work. You need to use SD and/or microSD cards, which max out at 2GB in size.
Sep 25, 2010 | Pentax Optio S5i Digital Camera
I turned on my TV last night. it did not have picture or sound. the blue light at corner was on around 10 second,and than blinking. can you tell me what happen to my TV.Thank you so much.
Give me model number of set, if blue light just blinks it means short protection--I can tell you exactly what to do to determine what problem is.
SD TECH MAKE A COMMENT HERE OR POST attention SD TECH AND I will assist you.
Sep 11, 2010 | JVC 47 in. LCD TV
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Transform Duo Stick into an SD card ~ Possible?
Hi Qwin,
Although you cannot directly use your Duo Stick in a camera which supports SD, you are able to purchase a memory card reader to support both formats. This means that you can transfer data from the Duo Stick or the SD onto your computer, and then put the data onto the other card.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 09, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Kenmore HE2 Plus Front Load Washer Logo
212 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
