Question about Bissell 6594 PowerForce Bagless Upright Vacuum
How can I tell if I need to replace the beater bar? I replaced the belt but now it seems too tight and the bar doesn't want to spin.
    Brigadier General:
  • 4,088 Answers
The belt is supposed to be tight, but the beater bar bearings are probably full of string, hair, and thread. Remove the bar, remove, clean, and oil the bearings (3-1 or similar). Leave the belt off for a moment, and install just the bar. Spin it with your fingers--it should revolve freely--if not, redo the clean/lube process again making sure to clean the inside of the bearings with a Q-tip swab. Once the bar spins freely, remove it to slide on the belt and reinstall. Hope this helps!
Posted on Oct 16, 2010
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
Why does Beater Bar Fail to turn
Per owner's manual
1. Make sure the brush control is set on carpet mode.
2. The brush will only spin when the handle is reclined.
Others:
The belt has worn out and needs replaced. Although it appears okay, stretching is possible, which would result in too loose a grip to turn the bar.
If the belt was replaced, it may not have been pulled tight enough to turn the bar. To tighten on many vacuums, simply loosen the screws on each end of the brush, pull toward the front of the power head and hold while tightening the screws.
Jul 25, 2014 | Dyson DC14 All Floors Upright Vacuum...
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
My beater brush will not spin. i cleaned it all off, but it will not turn when i turn the vacuum on
1. if you are smelling burnt rubber and hearing a loud squealing then your belt is tight but something is binding up the beater bar, more than likely if that is the case you need to take out the bar and see if the ends are packed up with carpet fibers, on the otherhand if the bar isn't moving and no smell or sound is present then more than likely your belt has slipped off the impeller shaft and all you have to do is pull it back onto the shaft, or the belt has snapped and you need to replace it
Feb 16, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater? bar doesn't spin
That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
Replacement Vacuum Belts
Dec 08, 2009 | Vacuums
The beater bar won't spin
Even though the belt is intact it can still be stretched and if it is it won't turn the brush roll when it's on the carpet. Here is a link to the belt you need and to a manual you can view:
Rainbow Replacement Belts and Manual
Nov 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
The brush isn't spinning
the belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
Jul 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Beater bar belt too loose
You need a new belt, they stretch after awhile and will slip.
Apr 07, 2008 | Vacuums
How to change belt on this model?
Changing the belt on this nifty little machine only seems difficult until you find all eight of the screws that hold the entire assembly together, and the nice thing is you get to totally ignore the torx style screws altogether.
There are two screws in the bottom of the unit just forward and to either side of the beater brush, remove 'em.
Flip the vacuum over and remove the two screws holding the top in place. One is located under the removable suction hose near the right rear wheel, the other is in plain sight over the left rear wheel.
After you pop the top off you'll see the dark clear plastic housing that covers the beater brush and belt assembly. It is held in place by four more screws, three on the back side of the beater and one on the front side in the center of the machine.
Change your belt, clean your brush and tell your kids to get back to work while you take something out for dinner and open a cold one.
Gregory Glaser
Fixer of broken things
Nov 08, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
116 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
