Question about Kitchen Appliances - Others
I try for different way to fence with wire #24 my antique chandelier.There are not way to pass the wires in the holes.They are very ,very small holes that never can see before. I'm sure that the wires cames with the lamp are #26 or less,but the problem is that I can't find that gauge here.Can you help me to find it or a good technique to fence with wire my lamp?
    Brigadier General:
  • 4,088 Answers
Can the small holes be drilled out to a larger diameter so that larger wiring can be passed through? The wiring should be at least #18 fixture wire unless the bulbs are very small wattage. Good luck!
Posted on Oct 16, 2010
Install chandler
The silver metal you refer to is a junction box. If you are installing a standard chandelier, a strap is mounted on the two round ears one of which is shown in your video. There is a hole in the middle of the strap and your chandelier attaches to that hole. With the chandelier suspended from the strap, you now have room to make the wire connections. When finished, the wire connections are pushed up into the junction box and the canopy is tighened to finish the job
Jun 15, 2013 | Home
Electrical conntection for Chandelier Tried to send problem twice before, but don't know if you recvd it. My problem is the wiring for install. outlet box has 2/blk/2wht/1red....fixture has...
use the same as when you took it down, white is neutral, red is power from switch, green is ground, look at wiring for new chandelier instructions should tell you what goes where, if al else fails get an electrician to wire for you
Sep 06, 2011 | Home
Can a jig saw rip fence (Skil rip fence model No. 94500), with adjustment on the shaft from zero to five inches, be used to make a circular cut with a 8 inch radius (i.e., a 16 inch diameter cutout)?
no, will never happen. Make yourself a jig, 1/4" plywood set on your table top woth a small brad set 4" from blade. make a tiny hole in board to be cut into circle, spin the board on the brad, and look a wagon wheel.
Mar 11, 2011 | Skil 94500 Jig Saw Rip Fence
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
My girlfriend has a leviton illumatech IP106 that keeps "not working". after a number of months. It is operarting a standard dining room 6 light chandelier. A couple of her friends have replaced this in...
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Oct 15, 2010 | Leviton Decora Light Dimmer Switch
Tried to install a ceiling fan to replace a chandelier. light on fan and fan itself works but only by the pull chains, it will not turn off or on by the wall switch that controlled the light. when i...
I can help with this but I need some more clarification. Does the switch on the wall not do anything at all, or does it turn them both off or on. The black wires are the power wires and the whites are your neutrals. You figure out what wires are coming from your switch. If there was a switch on the wall that controlled your chandelier before that there has to be a white and black wire that go to that switch. Look at the switch in the wall. If all you see in the switch box is a black and white wire then they did a switch loop, which means they started the power up in the fan box, sent it out to the switch through the white wire and brought it back to the fan through the black wire in which case the one white wire up in the fan box is a powered wire. If there are four wires in the switch box (2 black two white), then they brought the power into the switch box, tied the whites together as neutrals and connected the blacks to the switch. So then up at your fan the white is neutral and black is power. To wire a switch loop at your fan, find the power wire, connect it to the white wire that goes out to your switch and the black wire from your switch will get connected to your fan motor and fan light. If it was not a a switch loop connect fan to the black coming from the switch and all whites will get tied together. Good luck!!
Apr 16, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Looking for help with the Whirlpool GR2SHK-XKQ00, top mount refrigerator. Water is coming into the refrigerator from the freezer, possibly linked to self-defrost cycle, def. not ice maker. Drain pan is...
Remove the lower freezer panel end then remove the rear panel . Remove the ice under bottom panel . Useing a hair dryer , heat the aluminum tray under the coils until you see the black drain hole . Continue defrosting the hole until free of ice . Could help useing a small screwdriver into hole . Even hot water into hole could help to clear . Once water will drain into hole , use a small hose inserted into hole and blow thru it to clear and obstruction in the line (line is inside the cabinet , unaccessable ) , Then find about a 14-16 gauge aluminum wire , aluminum fence post tie , aluminum ground wire , and insert it into the hole until resistence is felt . Wrap the top portion about 1 turn around the calrod (black) heating element and cut off the rest of the aluminum wire . The element will transfer heat to the wire during defrost , to keep the drain hole clear of ice .
Jul 22, 2009 | Refrigerators
Rotary dimmer control for 5 light chandelier stops dimming
Whoa...You definitely may have a fire and/or shock hazard hanging from your ceiling. I've seen a lot of fixtures with old, brittle wire and bad insulation in them. Lamp wiring is subjected to a lot of heat, especially with higher-wattage fixtures. Long term exposure to heat near or above the insulation's rating is especially damaging to electrical insulation. I've also seen cases where metal parts of the bulb socket partially melted and/or broke loose.
If you're comfortable and confident of your abilities to make a safe electrical connection, you can replace the wire and bulb sockets in your fixture. If it's valuable or an attractive antique, it's worth fixing or having fixed, even if you sell it. Just make sure you use wire with insulation rated for use in an electrical fixture. It must be rated for a temperature no less than 105 degrees Celsius.
It it's a lower cost fixture, replace it or have it replaced. Regardless of what you do, you're probably going to be replacing that dimmer again...sorry.
If you live in an older home, it may be worth (in terms of safety) having a few qualified electricians evaluate your electrical system as a whole to make sure everything is still in safe condition.
May 04, 2009 | Rotary Lot 10 Leviton Ivory Light Dimmer...
Kitchen Appliances - Others Logo
56 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
