Question about Husqvarna 20HP Hydrostatic 42" Cut Riding Mower
The mower runs and moves but acts like there is no power to the wheels? Have like 1/4 power to the wheels if that. has 45 hours on it 1 year 1month old.
    Problem Solver:
  • 10 Answers
Replace the drive belt
Posted on Oct 16, 2010
My Wheel Horse mower acted like low on gas so I filled it. Turned on the mower blades and off and on when moving and it seemed like a belt slipped. It ran unevenly, quit running and won't start.
Even if you have slipped or broken the blade belt, that would have nothing at all to do with keeping it from starting UNLESS you are trying to start it with the blades still engaged. Check that.
Jul 02, 2016 | Garden
Will run but doesn't move
If it doesn't move at all; I would check the drive belt first, then the belt idler pulleys. Just make sure that no one has put the hydro units in bypass mode so they could move the mower without the engine running without your knowledge..
Feb 28, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
Mower will not go forward .... it runs .... and the deck still engages but will not move forward or backward
i would inspect the belt the mower and the trans operate from different belts
Jul 10, 2012 | Garden
John deere sx85 will not move
make sure the belt is tight
Mar 31, 2012 | Garden
Toro self propelled rear mower recycler.. starts and runs fine..Then stops if you do not keep the propulsion in gear
I would say that something inside the mechanism that engages the self-propelled action has broken. When you release the lever, (most of the way), that keeps the S.P. action moving, it's suppose to flip the action off but keep the motor running. And when you release this same lever all the way, it acts as a kill switch. If your wheels never disengage, then I would look at the mechanism spoke of above.
If you hear this mechanism click when you release this lever, this is good and it's not broken. Then you may have grass and junk clogged up under the cover where the front wheel is. This would also keep it from disengaging.
Good Luck!
Jim
Aug 19, 2011 | Toro Power Lawn Mower
Metro walk behind bogging down
the springs that control carby is there leaves or grass stopping it from moving ,some lawn mowers have bad desinge for air flow off ****
Jun 02, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Logo
173 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
