When i try to reset the box the white light blinks for about 2 to 3 minutes the an orange light comes on and stays on . it won't reset
  • Jim Walker May 11, 2010
    What product are you referring too?
Try holding the power button in for 4 seconds this forces the powers supply to shut down then press power on
this process simulates a reset
Posted on Jun 04, 2008
Have solid red light at the 7 o'clock and blinking red light at 11 o'clock
[PDF]Download XD1080 User Guide - Replay XD
www.replayxd.com/downloads/.../Replay-XD1080_User_Manual-EN.pd...
Note: The red LED on the rear will blink when the memory card is not inserted .... The Start REC button should always point up or at the 12 o'clock position for a ...
LG TV Blinking - YouTube
? 0:43
https://www.youtube.com/watch?v=Q8JG53DU6Rk
Nov 5, 2015 - Uploaded by Gillet Gaming
My TV suddenly started blinking when I turned it on at 12o'clock. ... I was going to use it when a few ...Missing: p
Diamond - ndxLocOut
www.nuforc.org/webreports/ndxsdiamond.html
11/7/15 18:05, San Diego, CA, Diamond, 5 minutes, Orange Diamond like .... 8/23/15 21:08, Wildwood Crest, NJ, Diamond, 2 minutes, Hovering red light, ... Diamond shaped brilliant white light with red light in eastern sky at 12 o'clock ..... flashing blue yellow the red at times staying solid red or blue seems to get bigger. 2/27/ ...Missing: p
[PDF]Air-Pak 75i SCBA - User Manual - Scott Safety
Dec 21, 2015 | Televison & Video
Vizio logo blinks orange/white for a minute then stops blinking. TV never comes on.
If there was a power surge, a power supply component may have failed.
Jul 01, 2014 | Vizio M550NV 55 in LCD HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
When our garage door opens, my light turns off immediately. How do I get it to stay on for about 5 minutes?
Try this:
Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates that the timer is reset to 1 1/2 minutes. Repeat the procedure and the light will blink twice, resetting the time to 2 1/2 minutes. Repeat again for a 3 1/2 minute interval, etc. up to a maximum of four blinks and 4 1/2 minutes.
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Thomson modem problem
Hi there.
The modem needs to be hard reset, on the back or underneath the modem you should find a small hole or button, you need to push this button and keep it pressed in for around 1 - 2 minutes, release the button and give the unit another 2 minutes to settle.
The wireless light should then go green or stay a static orange (not blinking)
If this does not resolve the problem it may need a firmware update.
Good luck
Jun 12, 2009 | Thomson Computers & Internet
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
