Question about RCA Scenium M50WH187 50" HDTV
I have a RCA M50wh92s DLP Tv.. I can turn it on hear the fan runing ... have picture for about 1 minute. then the tc shuts off... power buton flashed 3 or 4 times and turns the tv back on and contines this cycle till you power it off
  • bigalscrib Oct 17, 2010
    I have the exact same issue with mine... did you ever get a solution for this issue
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
ladywinn
  • 5138 Answers
SOURCE: RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
you have a bad capacitor around flybackor neer by transformer.
Posted on Jan 17, 2008
joboo1
  • 257 Answers
SOURCE: My RCA 50'' DLP Rear Projection TV will not turn on
Hi, This could be several things as the power goes everywhere. Long distance troubleshooting so hang in there. First try a cold reboot by unplugging and replugging after 30 minutes. If nothing check P1 on the light engine for the following voltages: pin 2 5vdc, pin 3 3.3vdc, pin 9 3.3vdc, pin 12 12vdc. If any of these are not good it is the formatter board. If all are good, does the color wheel spin at all. If this is OK then check J4 on the light engine, the ballast enable line should be 0 vdc in stby, .5 vdc at turn on, and 2.5 to 3.25 vdc in run. If good, is the light engine trying to fire the lamp? If not, inspect the J4 connector and the lamp power supply, If they look OK then the lamp ballast is probably bad. This will give you something to do for now, Good Luck!
Posted on Feb 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Posted on Sep 07, 2009
  • 131 Answers
SOURCE: I have an RCA DLP M50WH72S tv. Powers up, picture
Hello; I am John at J D Electronics in Poland Maine. I have had an RCA model M50WH72S setting dead in my shop for over a year now and is now mine. The set would start intermittently and run for an hour and die. Other times it would not start at all and the LED would flash 5 or 6 times and stop. With no support from Thomson/ RCA, I was on my own. The extended warranty Co said to try the light engine first. I replaced the light engine with no improvement, just the led flashing. I was not going to pay 500 to 700 dollars for other boards to try to fix this piece of JUNK.I have since read several blogs that point to power supply caps as being the problem. I took this piece of junk apart for the last time before I hauled it to the dump. I pulled out the power supply on the left as you face the back of set. I noticed 2 Electrolytic caps had " domed shaped tops ,which is a good sign of failure or overheating. They are 1000 ufd @ 35Volts 105 degree rating. They were both bad along with 2 more on the same board ! They are labeled CP624 and CP647 on the bottom edge of the board inside the "c" shaped heat sink. The other two are above the chopper transformer labeled CP641 @ CP639. replacing these fixed the set. Call DigiKey 800-344-4539 part # 493-1588 are ten for $7.00. Don't spend money on a lamp you don't need.
Posted on Jan 10, 2010
Zenith z56dc1d dlp tv picture works for about 1 minute then starts shaking and tv shuts off
You may want to get it in a rather warm room and or remove rear cover and use a hairdryer to warm everything up inside the Cabinet--with rear cover off look to see if the fans are dirty etc and if they all come on, if a DLP especially look at the lamp itself and the fan that cools it.
Dec 18, 2012 | Zenith Televison & Video
I have an RCA M50WH92S and when i turn it on the power light flashes 5 times and no picture. I have replaced the bulb today. any ideas?
first is parts for this set can get expensive---I would do two things first:
1. Look to see if lamp comes on at all--even for a few seconds.
2. Look with lamp removed where it faces to see if color wheel broken/shattered or missing pieces of the wheel.
If the lamp does not come on the next suspect would be the Ballast which powers the lamp---if its bad you may or may not get sound either.
Dec 09, 2012 | RCA M50WH92S Bulb
RCA M50WH92S PICTURE COMES ON FOR ABOUT TEN
Replace your LAMP if all of your Fans are running! If lamp fan is not running Lamp will not turn on .Call FOX for Lamp 1-800-227-5369
Jun 20, 2011 | RCA Televison & Video
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Rca projection tv wont stay on but about 1 min then powers off and wont turn back on for about ten minutes then shuts off again after a min or so
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
Sep 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 50'' dlp model # M50WH92S turns off, light blinks 3 times
Dec 25, 2009 | RCA Televison & Video
Rca m50wh92s dlp projection tv
it is the lamp...easy fix
Jul 07, 2008 | Televison & Video
My RCA Scenium 50in. is not turning on!!
Its sounds as if the lamp has exploded or the color wheel has. I will post a link to a site that has a trouble shooting manual on CD called RCA DLP Disc #1 which covers every DLP in the ATC line which is what your model is. They have it either in cd form or they will email it. Its a very good resource for fixing your own set.
Jun 16, 2008 | RCA HD50LPW175 50" HDTV
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA Scenium M50WH187 50" HDTV Logo
131 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
