Replace waste toner container on lanier 6625
Need help to remove the waste toner container. Any idea on how to do it?
  • 1 more comment
  • melthemom Jun 09, 2008
    Bubbabear64,
    I fixed it. thank you for your response.
  • Anonymous Mar 27, 2014
    waste toner
    waste toner
  • 2,794 Answers
Can you verify the model number once again? If there are letters in the model number, that would help as well.
Is the copier black and white or color?
Posted on Jun 09, 2008
Hoe do I empty the toner waste on an old Lanier 5645?
Its the brown belt thing on the right door, take off the 2 springs and remove the belt assy and empty, very messy...-Carl
Oct 16, 2014 | Lanier Office Equipment & Supplies
Lanier 5235
The waste toner is contained inside the belt unit that is mounted on the inside of the right hand door. Remove the screws that hold it together and dump it. Very messy so be careful. The message will go away by itself.
Jul 02, 2014 | Lanier 5235 Printer
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
The screen on my Phaser 6110 MFP says "Remove/Install Waste toner tank." I don't know what that is.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
and use it to close the waste toner container opening.
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
that it is firmly seated in place.
7 Close the front cover firmly.
8 Turn the machine on.
Caution
If the front cover is not completely closed, the machine will not
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 16, 2010 | Xerox Office Equipment & Supplies
Where is the toner waste on the Lanier LD445C?
The only reference to "waste" is the punch waste. I could not find the "Toner waste" in the manual:
Open the Finisher front cover.
Pull out the Punch waste box carefully.
http://www.lanier.com/downloads/manualFrame.aspx?path=http://support.ricoh.com/bb_v1oi/html/oi/lan_u/model/mp35/mp35en.htm
Nov 30, 2010 | Lanier Office Equipment & Supplies
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
1 Turn the machine off, then wait a few minutes for the machine to cool.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Printer won't print
The PCU is behind the right door, remove the waste toner and its the one on the left.
-Carl
May 27, 2009 | Lanier 5235 Printer
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Apr 10, 2009 | Lanier Office Equipment & Supplies
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
137 people viewed this question
jasbo
jasbo
