Question about Frigidaire FRS26ZSG
FRIGIDAIRE FRS26ZSG - WATER DISPENSER
The unit shoots water out of the water dispenser sporadically. It seems to coincide with what should be a fill cycle for the ice maker. Is something diconnected and causing "ice water" to become "drinking water" ??
Please help before my wife makes me buy a new refrigerator !!!!
Don
  • 3,037 Answers
This only happens when the ice maker is being filled? Does it seem like excessive pressure? Is the water volume still the same? The first thing to try is, just to do a full defrost of the unit and see if that de-ices the device. You may have a buildup in the tube or the water pump may be the problem. When the ice maker isn't filling though, is the water dispenser normal or is something still wrong with it?
Please get back to me on this and tell me what you have tried.
good luck
Posted on Jun 03, 2008
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Sergeant:
    Champion:
  • 230 Answers
May be your refrigeretor is in deepress mode in that mode the ice maker will not work check that and change it to normal mode
    Brigadier General:
  • 3,614 Answers
May i know the exact model of your ref..? kindly check out the selenoid area..
  • micromaster
    micromaster Jun 03, 2008
    check also the water inlet valve & the water supply line for any clogged water line or a defective water inlet valve.
  • micromaster
    Please post & let us know if this initial info helps you..
    Regards
    Master:
  • 555 Answers
Is there an overflow module that connects the icemaker to the water dispenser? If you are still getting ice, it is probably just extra water.
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Water does not put water in tray drinking dispenser works good what can be the problem water supply hose is clear thanks
First check the water flow.Is the water flow running.If the water flow is blocked then no water will enter the dispenser.If water is running properly but its not entering the water dispenser then check the water tube,is it kinked or got loose or got blocked.But if water is running ok,and water tube is proper and not blocked or kinked.Also connected properly to its hose Then the possibility is water valve,this is at the back of the ice maker unit.There is a twin valve,which lets the water enter the ice dispenser and water dispensing unit.But if the valve is blocked from one side or faulty then it will not let the water to get dispensed.Also in some cases the ice gets clogged in the water fill tube and this creates the problem.If there is ice frost problem then you can use hair dryer to melt the ice collected in the water fill tube.But take care you unplug the unit from main power outlet before doing this.Its for safety reasons. If the valve is faulty then it has to be replaced.And you can get required parts from online sites like,sears parts direct or from repairclinic.com --------- This will help.Thanks.Helpmech.
Dec 19, 2010 | Frigidaire FRS23R4A Side by Side...
Our GE Profile side by side refrigerator is making hollow ice cubes and the water dispenser comes on by itself sporadically for about 3 seconds a few times a day. Over night it filled a whole glass of...
Hello. Hollow cubes is caused when there is not enough water going into the ice cube molds. That said, since you have too much water going into the water dispenser I would suspect that the valve needs to be cleaned or possibly replaced. Joe
Mar 27, 2010 | GE Profile¿ Arctica® Energy...
Water spurts from on top of water dispenser unit
It will need to be taken apart and inspected for obstructions or cracked tubing
Nov 25, 2009 | Frigidaire PHS69EHS
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
No water to ice maker
Be sure that the water supply is on, and that the plastic water hose is not kinked, blocked or frozen. Mine was twisted at the bottom left door hinge.Also, check the black microswitch behind the ice/water outlet. Mine was sticking. Just a couple bucks at any Electrical Supply distributor.
Hope this helps,
DrD
Jun 09, 2008 | Frigidaire FRS26ZSG
Auto Water Dispenser
that maachine shoulnt work with out the filter inplace, all i can suggest is replacing the filter.
Mar 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Refrigerator - Model # FRS26ZSG
The housing is probably cracked due to it freezing.
Dec 02, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
103 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
