Question about Westclox 181961 Omni II Clock Radio
HOW DO THE SET THE TIME ON MODEL # 1819 CLOCK
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Spartus model 1819
How do I set this clock?
Nov 10, 2012 | Cars & Trucks
How to set time on model 13003
Hello
Get into this link. You can get all the details for your clock radio from there.
lib.store.yahoo.net/lib/partshelf/Acu-Rite-00592W-Manual.
Nov 17, 2011 | Acu-Rite Adagio Clock Radio
Need to know how to set time on ISTA SET 40009
Instructions
    • 1 Press and hold the "Alarm Set" button for five to seven seconds if you have an Insta-Set 40001, 44100 or 44200 model; the year will begin to blink when the clock is ready for adjustment. If you have an Insta-Set 40009 or 40018, hold the "DST" button for five to seven seconds (until the hour begins to blink).
    • 2 Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
    • 3 Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
    • 4 Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Read more: How to Change the Time on an Equity Insta-Set Clock ' eHow.com http://www.ehow.com/how_5657092_change-time-equity-insta_set-clock.html#ixzz1d1qIibS4
Nov 07, 2011 | Equity Time USA Insta-Set 40009 clock
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Tivoli model three clock problems
SELL! SELL! SELL! Yup the clock has bit the dust sell er and cut your losses.
May 12, 2009 | Tivoli Model Three Clock Radio
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
Westclox 181961 Omni II Clock Radio Logo
362 people viewed this question
Top Westclox Audio Players & Recorders Experts
pawnpower
 Grubhead
Grubhead
ka4iup
ka4iup
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
