Question about HP TouchSmart IQ770 PC Desktop
How to dismantle a hp touchsmart iq772.uk .the graphics card needs replacing
  • 5 more comments
  • akramshow Oct 16, 2010
    it s easy to remove the top cover and the back cover..but it only reveals part of the mother board and it s impossible to get to the graphics just by doing that..so the answer is not it
    hi.i have a hp touchsmart iq772.uk..it powers on but the screen stays blak.i want to replace the graphics card and apart from removing the top and back cover i could not go any further..i want to know how to dismantle it to get to the graphics card..thanks
  • akramshow Oct 17, 2010
    how to dismantle the hp touchsmart iq772.uk..the graphics card needs replacing..how do i get to remove it knowing that removing the top cover only reveals part of the mother board and not all of it..thanks
    i ve done those steps..anyone can do those..i m asking how to get to the graphics video card to remove it..thanks
  • akramshow Oct 18, 2010
    THAT S NOT IT..
  • akramshow Oct 19, 2010
    how many times do i have to tell you that that s the answer..that does not reveal the video card..dnt u understand english?
    it s not it can be replaced.
    Guru:
  • 731 Answers
    Scholar:
  • 29 Answers
HP Touchsmart IQ775 - Disassembly Procedures.
Start at the Back of the LCD part:
1. Looking at the left side of the body back cover,
remove the screw at the top of the power cord socket.
Remove the screw at the top of "IR out". Then slide the body top cover towards you.
2. Disconnect the DVD cable, then pull-up the left black lock to release the DVD drive.
3. Looking the neck of the LCD, there is a slide switch to release
the cover of the HD. It's located above the OEM key sticker.
Press it down then the back cover will release.
4. Remove the 4 screws, 2 each side of the ports (usb, Ethernet/connections) side.
5. Remove the 3 screws of the CPU fan.
6. Remove the 2 screws at the edge side of the motherboard.
7. Remove the 2 screws at the middle part of the motherboard.
8. Remove the 3 screws of the metal face upper plate.
One the right middle part and the other one in the middle is a long (1.5")
and the other is located at the edge of the left of the power supply.
Next is the front of the LCD part:
9. Remove the plastic cover where the OEM sticker located.
You can use flat screw driver and pry it around. There is no screw to this plastic.
10. Remove the shiny metal by removing the 6 screws.
Note use the 3" tall Philip screw driver for this part because of the space so limited.
11. To remove the plastic covering the buttom dome part is tricky.
Start at the back, release the 3 hooks type from the metal body frame and
press down at least half-inch downward. Then wiggle and push it the right
side and remove it towards you, assuming you are facing the front of the LCD.
12. Now the SECRET PART, there are 2 silver screws hiding under the sticker.
Open the door of the Connectivity. Next peel-off the sticker
saying (L) Audio (R) input. You'll going to see a silver screw. Do the same
at the other side of USB 2.0 and remove the screw.
Making diagram and labeling of cables:
Note I drew and labeled each cables by using 3M Scoth's Tape for
labeling and paper and pencil for their specific locations.
This is very important. I used big needle in releasing the Bluetooth wire.
Pry it to the side and be patient. Don't pull the wire it is very fragile.
13. Note: the plastic cover for the front face (DVD's play, pause, eject)
is not suppose to remove because it is screwed together with the metal frame.
14. If you are facing the front of the LCD, use your left hand and
lift the metal frame starting at the back. Then the right hand at the
other end of the metal frame. Lift it about 1" and wiggle it. Then push
it towards you. It should release and then remove it. Pull it slowly and
you'll going to see lot of cables. This is the part to draw the locations
and labeling of each cable before removing them.
15. Remove the 2 screws from left and right edge of the motherboard.
The right edge screw is hidden under the LED lights' wire. Just make way and remove it.
16. Removing the power supply's molex connection is tricky.
I used flat screw drive to separate it from the motherboard.
17. Now twist around the computer and facing the Back part
of the LCD part. Note there is a PCI WinTV adapter connection under the motherboard.
18. Lift the motherboard straight upward by gently wiggling it.
There will be a little struggle it should release after a while.
Aside from the PCI connection, there is a thermal sticky on the Intel chip.
19. Done. And the rest is easy.
Note: I replaced 16 pieces of bad, leaking and defective capacitors. These are the:
7 pcs - 6.3v 820microfarad
6 pcs - 4.0v 680microfarad
1 pc - 16v 100microfarad
2 pc - 6.3v 330microfarad
Note: I also improved the heatsink of the GPU (graphics card).
By placing a 2" x 1" copper by connecting it the metal frame of
the DVD drive's metal. The reason was because the temperature
around the GPU was above 70 degree Centigrade. By connecting the
piece of copper thru the neck of the heat sink GPU together with
metal frame the temperature dropped by at 10 degrees.
Roan
Posted on Aug 16, 2011
  • pedrovich
    pedrovich Sep 05, 2012
    Are there any replacement cards that fit this slot for the iq772? How much do you charge to revamp the go 7600 mines died? Thanks
  • 3 Answers
Pretty easy. there's no support for this computer on the net but i may be able to help. how to dismantle a hp touchsmart iq772.uk .the - iq770.jpg
Posted on Dec 05, 2010
  • 0atom Dec 05, 2010
    this computer has a video card for the folks that says it doesn't
    Photobucket
    President:
  • 3,278 Answers
Hello.
Unfortunately, the graphics card is integrated with the motherboard on these models. It's not a simple matter of replacing the graphics card.
Not what you wanted to hear, but hope this helps.
Posted on Oct 17, 2010
  • NinaE Oct 18, 2010
    Your graphics card is NOT integrated with your motherboard ??
    incorrect
    Genius:
  • 1,035 Answers
Hi. If this is the product number of your computer (GS275AA). Then the video card is on board. Meaning it is built in to the motherboard and you cannot replace that one.
  • 4,889 Answers
Replacing the card should be easy. You should just remove the cover at the top by removing the screws holding it in place. The card should be inserted into the PIC/PCI-E slot on the motherboard.
Sai.
Posted on Oct 16, 2010
  • 1 more comment
  • eagle338
    eagle338 Oct 18, 2010
    Then you should tell me where exactly you are stuck. If you can get me a pic or something I can help you solve this. May not be such a good idea to keep swapping experts as none of them will be able to arrive at a conclusion.
  • eagle338
    whats not it? I wanted to see the image so as to see whether the grill kind of thing is blocking your view.
  • eagle338
    eagle338 Dec 05, 2010
    I am not asking you to show me the card. I am asking you to get me a picture as to what part you are not able to remove so that I can help you. If you want to be rude, I am gonna have to ignore your replies from here on.
Blank screen
I'm a bit confused? All-in-one's don't have Graphics Cards, it has a Graphics Adapter. Take a look at HP Support: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=43110&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3351220
Mar 24, 2013 | HP TouchSmart IQ770 PC Desktop
Change the Video Card
No, the graphic card is build in on the mainboard and can not be upgraded.
Dec 13, 2012 | HP TouchSmart Elite 7320 21.5" FAll-in-One...
Boots up without images on the screen
The graphics card in the PC is very likely faulty. It is possible to remove the graphics card and reconnect the monitor cable to the onboard graphics. Look on youtube for help on removing the graphics card (try a search for iq772). The monitor connector is at the front of the motherboard, near to the graphics card. re-connect it to a similar connector to the left to use the on-board graphics.
Dec 10, 2011 | HP TouchSmart IQ770 PC Desktop
What to do when you turn on computer and see multi vertical colored lines?
This is a known problem with the touchsmart desktops. The cooling on the motherboard and graphics card has a dreadful design and the graphics processors overheat.
The graphics card needs to be replaced, and the HP part number is 5188-7147
Aug 08, 2010 | HP TouchSmart IQ770 PC Desktop
The graphics card on my hp Touchsmart IQ770 computer is u/s and I need to replace it but I am not able to get one from anywhere.the graphics card is a geforce go 7600do you know if an alternative card can...
Not to my knowledge, The original they used to build this is mounted flat to the motherboard due to space requirements. No other I know of will work without a custom made adapter.
Jun 22, 2010 | HP TouchSmart IQ770 PC Desktop
I have a hp iq780 touchsmart pc.recently nvidia 7600 graphic card got crashed & its display got corrupted so, i switched to the motherboard graphic card nvidia 6100.wanted help in recovering 7600...
if the hw is working fine then you can go to the device manager and uninstall the driver ... and then go to the nvidia website and install the driver sw for it
Mar 17, 2010 | HP TouchSmart IQ770 PC Desktop
My Touch Screen to my HP IQ770 is not working!
There is a well known problem with the graphics card, which suffers from over-heating. You can buy a replacement card (very expensive) or remove the failed card and then attach the monitor feed to the output from the (unused) onboard graphics card. You lose some 3D capabilities, but in normal use you won't know the difference.
This process is described on HP Touchsmart Dev Zone website.
Mar 04, 2009 | HP TouchSmart IQ770 PC Desktop
Nero 8 and conflict with USB 2.0 built in computer camera
Uninstall that one you have installed on your pc and download this one.Portable is it!
Download
Dec 27, 2007 | Computers & Internet
HP TouchSmart IQ770 PC Desktop Logo
3,174 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
