Question about Kenmore 22642 Top Load Washer
Working on a Kenmore 80 series (11020872990) washing machine, do you remove the rear panel or the front/sides panel?
  • Kenmore Master
  • 2,330 Answers
No don't touch the back at all.unplug it,then pop off the white end caps on the console and remove the two phillips screws,lift up the console,unplug the lid switch connection in the top middle and with a screw driver pop off the metal clips,just stick the screw driver in the hole and on top of the clip and just push towards the back wall and it will pop out,then open the lid and tilt the frame forwards and back at you and remove the hole outside frame.what problem are you having?let me know how you make out
Posted on Oct 16, 2010
  • Sal DeAngelo Oct 17, 2010
    how'd you make out with the machine
How do i get the back off my kenmore hd 90 series washing machine
YOU DONT!!! THE 90 SERIES COMES OFF OR OUT DIFFRENTLY. THE WHOLE BODY IS REMOVED BY PULLING IT FORWARD AFTER REMOVING FRONT SIDE PANELS THEN UNSCREWING 2 SCREWS. CAN THEN PULL OUT WHOLE BODY FORWARD
Oct 18, 2014 | Kenmore Washing Machines
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
Jul 07, 2011 | Kenmore Washing Machines
How do you remove the back panel of a kennmore 80 series washer machine
The back panel does not come off. You need to remove the whole front cabinet. Here is a video to show you how it's done.
Jan 06, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore 80 Series washer that started leaking just a little a few weeks ago. Checked all the exterior hoses and they are fine. Today it leaked worse. It appears to be coming from the front not the...
You have a hole in the water pump.
You need to remove the control panel.
Locate two gold clips, one on each side of the unit.
Remove clips, open the lid and pull the cabinet toward you. Water pump is right in front at the bottom.
Sep 03, 2009 | Washing Machines
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing machine
ck lid switch also ckd hinge screws that looks like newer moder with switch under left side of console try pressing left rear corner of lid or listen for clock when lid is shut slowly
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 BALANCING PROBLEMS
Wiz, That black piece of foam is just a sound dampening strap, no big deal. This is a hard one, I see a lot of these vibrate when there is a false floor. Here are some things to check: makes sure the front legs are locked with the nut. Check to see that all the springs are attached and the plate is centered, I will attach a photo. Depending on whether the machine is walking or just the tub banging, it could be the drive block for the basket. You will have to remove the cabinet or tip it back to check the springs. Catriverdf505ed.jpg
Jan 28, 2008 | Washing Machines
Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Nov 01, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22642 Top Load Washer Logo
233 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
