Question about LG DLE5932W Electric Dryer
The dryer heats up, but not hot enough to dry the clothes. Have cleaned all the vents and have good air flow.
  • LG Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
My dryer is an Inglis, heavy duty 6 cycle, 4 temp, autocycle that is about 7 years old. Recently it just heats up but does not dry the clothes. They are steamy hot but wet. I checked the vent, it is not...
It sounds like the blower is not forcing air through the dryer. I would start by turning the dryer on and checking the vent exhaust to see if there is a good healthy air flow where it vents to the outside. If there is not good air flow, start back tracking the air flow for obstructions or other problems. Check the lint filter to be clean, check the air piping to be clear, check the blower to be clear and functioning.
Oct 03, 2013 | Dryers
Dryer gets hot but does not dry. It seems to keep the moisture in as of there isn't any air flow. I cleaned out the vents and air duct but still wont dry
This definitely sounds like a clogged vent. 1) disconnect the vent from the back of the dryer. Turn the dryer on and make sure your getting good air flow from the vent outlet. 2) if the air flow is good then your definitely have a vent that is clogged between the dryer and the outside of the house. This is the most common cause for the dryer to not dry the clothes.
Jan 13, 2011 | Dryers
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
My LER463rJQ1 dryer is only about 4-5 yrs old and it doesn't seem to be heating as well anymore. I don't know where to start...thermostat? heating element? or what.. What do you suggest.
I assume you mean the clothes are not drying as well or as quickly as they use to.? If so I would start with the Vent system ,85% of extended dry times are vent issues. Start by running the unit and going outside to the dryer vent and check for a good flow of warm air,if very little air is coming out of the vent you need to clean or have the entire exhaust system cleaned out.. With out good airflow you will just end up with warm moist clothing the airflow helps remove the moisture.. If not a airflow problem it may have a thermostat issue not letting it get hot enough or not staying hot long enough,,Hope this helps GOOD LUCK
Aug 27, 2010 | Whirlpool LER4634J Electric Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
LG DLE5932W Electric Dryer Logo
79 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
