Question about Braun 9595CC Electric Shaver
Why does my clean and renew station leak all over the counter when a new cartridge is installed? Braun 9585 Electric Shaver when cleaning shaver for the first time after a new cartridge is installed liquid starts running all over the counter. I have not tried anything to fix it.
  • 12 Answers
I figured out the problem for my Clean & Renew unit. Mine is 2 years old. About 3 months ago, I cleaned the buildup of whisker material from the TOP of the drain port [Left Side as you look at the unit] If you take out the cleaning solution cartridge and turn the unit upside down, you see the pump and the return ports. The return port is the smaller of the two. I found that there was a mass of dried whiskers in a few clumps clogging the return port. These clumps must have come loose and got caught within the drain port. I had noticed when I had the leaking problem I could hear bubbling just after the pump ran and the shaver turned off. I removed the clumps of whiskers and no more bubbling sounds and NO MORE LEAKS. My guess is that the fluid was draining back into the intake area and leaking on top of the cartridge. Hope this helps.
Posted on Dec 11, 2010
  • ScottE9999 May 05, 2011
    I used a twist-tie and the brush that came with the razor to clean out the drain hole, solving my leakage issues.
Craig: Same thing happened with my 8000-series razor. There's a tiny drain hole on the left side (looking from the front) of the cavity that holds the razor, and, on mine, it was clogged with whisker debris. Cleaning it out with a toothpick was easy, once I knew what the problem was. Thanks.
Posted on May 10, 2013
  • Some Guy
    Some Guy Jun 22, 2014
    For a while this worked for me, however now it seems to be leaking from somewhere else, no matter how clean that left drain port is.
When I put my Braun series 7 in the cleaning station everything is good. It pumps liquid up to clean then it starts to pulse and the vibration shuts the system down. I redo it with the same result.
I wonder if you can charge the shaver with the cord. Or is the battery dead?
Please also check if the blades of the shaving head are pressed on correct. It is the cleaning system, what pumps up the fluid, and after a while is the the shaver that should start pulsing. So it must be an error with the shaver. If the shaver works normal but does not when not in the cleaning station, also check the contacts on the shaver and on the cleaning station.
Jan 10, 2015 | System Clean 6 Braun Syncro Shaver & Renew...
I replaced the cleaning liqud cartridge but it shows the red light indicating it is empty.
here is the solution..follow the steps please..
Thanks in advance for rating me..Regards
  • Replace the cartridge in the base station and close it.
  • The indicator light should cycle then change to green. If it doesn't then unplug the base station, wait a few seconds, then plug it back in.
  • Press the lock button to clean the shaver. If everything went well it should start cleaning like normal.
    Aug 27, 2010 | Braun 360° Complete Electric Shaver
    Braun 5790 leaks and floods counter when charging/cleaning!
    Jul 30, 2010 | Braun Flex XP II 5790 Electric Shaver
    Clean and Renew stand for braun 8595 does not seem to cycle properly...after shaving and placing in unit, it randomly seems to clean and is stuck on cleaning cycle (normal light blinking, no charge) I then...
    The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
    May 10, 2010 | Braun Activator 8595 Electric Shaver
    Braun 8595 clean and renew will not charge or clean my razor, in fact it just ignores my razor
    it sounds like your clean and renew base will need to be replaced. you will find a replacement at shaveroutlet.com
    Dec 17, 2009 | Braun Activator 8595 Electric Shaver
    My 8585 braun shaver will not clean the lights flash but nothing
    my braun 8585 is five years old and i would like to have it serviced and referbished, please let me know the cost if this is possible?
    May 29, 2009 | Braun 8585 Electric Shaver
    New cleaning solution cartridge leaked
    If you both have the same problem from the same merchandise, than maybe you should just switch razors and Rely on a different company.
    Jul 28, 2008 | Braun Syncro 7526 Electric Shaver
    Braun 9595CC Electric Shaver Logo
    3,152 people viewed this question
    Top Braun Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
