Question about Dell Computers & Internet
Dell Latitude D810 laptop. When I hit the power button the power light comes on, and within 3 seconds the system shuts off. It will not boot to BIOS. I've tried it with/without a hard drive and with/without the battery installed. Can you lead me in the right path to fix it?
  • 60 Answers
Try removing the memory, hard drive and battery. With the system plugged in (obviously) see if it will boot. Be sure to remove both sticks of memory. One should be located on the bottom of the system and the other should be located under the keyboard. *NOTE* Once the battery, hard drive and memory have been removed, before you plug the laptop in, press and hold the power button for about 5 seconds. This will drain any remaining power. If your system still does not boot, I would say that they problem is with your motherboard. If the system does power on, shut it down and replace your components 1 at a time until you discover which part is possible defective. Keep in mind that only the motherboard has to be an exact match. Other components that may need replaced such as memory only need to be compatible, they do not need to be from Dell.
Posted on Oct 17, 2010
Testimonial: "I followed your directions and found the problem! Thank you so much for your help, you guys are awesome!"
  • 1 more comment
  • Dale Niles Oct 17, 2010
    To cahollins: You are welcome. Glad that you were able to resolve your problem.
  • jack880 Nov 10, 2010
    Hi Dale. I was wondering if you could help me too please? My dell precision M70 won't turn on. When I press the power button the bluetooth, power and AC power lights come on and nothing else happens. The computer stays like this and won't boot. I've tried it with the RAM swapped around (it has 2 modules), with no RAM in, with the hard drive and battery removed. I've even taken everything off my laptop and bought a new base with motherboard and put all my components onto the new motherboard and the same thing happens. Is it possible it's the processor do you think?? Many thanks, Jack
  • Dale Niles Nov 10, 2010
    To jack880: It may take me some time to find a solution to your problem but off the top of my head, I would double check the memory modules, if you can, in another laptop. Also, there is a possibility that there is a connection that was missed.
Dell latitude d810 power up issue
There is most likely either a problem with the power supply or else the CPU is overheating and causing a safety shutdown. There is not much you can do to check the power supply, but you can check to ensure that all ventilation ports are open and clear of dirt and debris. Also ensure the cooling fans are operating when you turn to unit on.
Jan 14, 2012 | Computers & Internet
The computer ignores the Power Management settings and shuts down when I close the lid. This laptop was supposedly refurbished by DELL. They loaded the BIOS for a Latitude D810 (same motherboard as the...
The Windows power management function seems to be very particular as to the system in which is is installed; I have seen similar uncorrectable glitches on a variety of systems and while the 'Hibernate' worked fine on our system for an extended time, it has since stopped working and refuses to come out of hibernation now. Frankly, it seems just one more of those annoying MicroSoft 'things.'
Oct 24, 2009 | Dell Precision M70 Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Dell latitude d810 laptop won't full boot on just battery power a
Connect the AC Adaptor to the Computer and turn it ON. Then, open the Run dialog box and type "msconfig" to open Microsoft System Configuration window. On the System Configuration window, click on the Startup tab then check if the checkbox beside the "LoadPowerProfile" program is marked. If yes, then shutdown the Computer. Then, remove the Battery pack and clean the Battery compartment and the metal contacts using a pencil eraser. Furthermore, you may try resetting the BIOS to its default values after reinserting the Battery.
Restart the Computer and keep on pressing the F2 key until the "Entering Setup" text appears on the screen. Then, press the "Alt+F" key to restore the BIOS to the default configuration. Then, press ESC and Enter to Exit and save the changes.
Sep 04, 2009 | Dell Latitude D810 Notebook
Computer will not turn on
Do you hear the hard disk spin up? is there a hard disk boot password configured? can you see a bios screen as it tries to boot? is the light on the power supply lighting up?
May 28, 2009 | Dell Latitude D810 PC Notebook
Dell latitude D600 booting problem
Are all three lights on when you hit the power button?
Aug 25, 2008 | Dell Latitude D600 Notebook
Dell Latitude C610 Laptop won't turn on
If the light comes on for three seconds and then go out ,generally means a power distrubution problem . remove the optical drive and memory from the system and try powering it on. If u get the same result , its time to take it to service tech , as your motherboard needs to be checked
Apr 07, 2008 | Dell Latitude C610 Notebook
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
440 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
