Question about Kenmore Sewing Machines
My needle broke off and now it wont sew without the thred underneat getting tangles up and caught on the teeth on the top on either side of the needle. We took it apart but can see no issues. Thank you
  • 132 Answers
Is the new needle seated properly? and if its a different size needle you need to adjust the feet also.
Posted on Oct 16, 2010
Bobbin does not sew: the upper thread gets tangles underneath but the bobbin thread is not involved
bird nesting indicates that the needle thread tension is not tight enough
pull the thread out as if threading the needle and the tension is close when there is resistance to pulling the thread
Oct 11, 2017 | Brother Sewing Machines
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
I have an xl2230.today the needle broke so i replaced with new one,and now the machine wont sew properly,its banging sometimes when it sews and the thread keeps breaking at the needle end and the fabr
try another needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
if none of these things help then I suggest the machine get's serviced just
incase the timing is messed up
May 31, 2012 | Brother XL-2230 Mechanical Sewing Machine
Thread jams starting with 1st stitch on Bernina 160
since a needle broke, & a new needle was put in, was the needle inserted correctly, normally flat side to the back of the machine, & pushed all the way into the needle holder
make sure the bobbin is inserted correctly into the bobbin case.
if none of these suggestions help, then it's possible that when the needle broke it could have caused the machine to jump time & would have to be checked at a sewing machine shop
May 21, 2012 | Bernina Virtuosa 160
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
Why does my thread keep breaking and why wont the sewing machine stich?
sometimes the thread can get caught on the spool pin
or on the notch on the thread spool itself
on some machines the thread can come off the thread take up lever
it can also get caught in the top tension area
also check your needle to see if it's bent--roll on flat surface to see if it rolls correctly
there are 3 types of bad needles-bent
blunt--makes a popping sound when going thru fabric
damaged--broke tip
also check your bobbin area for lint or loose threads
check your bobbin to see if it's warped--I've come across some that were warped
check your top thread tension
Sep 24, 2010 | White Sewing 2200 Multi-Tasker
Stop for Safety Purposes ?
I have had this happen to me many times. It really does feel as though the problem is in the bobbin, but it's not. After much aggrivation I took it into the repair shop and found out the thred was comming unhooked on the top not in the bobbin. It still happens all the time but I know what it is now so I just rethred the top.
Sep 16, 2008 | Elna Heirloom Edition 6005
Bottom stitch keeps getting tangled up after needle change
Sounds like the needle has hit the hook.Open the bobbin area door, remove the bobbin and bobbin case. The swing the two lugs that hold the hook retaining ring to the side so you can remove the hook. CAREFULLY inspect the sharp tip of the hook. It will be sharp and 'chisel' shaped. ANY marks, scratches or burrs on the hook must be removed carefully with 180 or 400 grit 'wet and dry' abrasive. It must be as smooth as a 'babies bum' !! If you are not confident, take it to someone to do it for you. The hook is expensive, so don't mess it up!
Oct 22, 2007 | Bernina Activa 140
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
