Question about Sanyo DP32649 31.5 in. TV
My Sanyo DP32649 keeps making popping sounds then the screen goes black 10 seconds later it makes a pop/scratchy sound and the screen comes back.
5 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: our sanyo dp42746 went black made a pop sound and
Most likely a power supply board went bad. the pop sound is bad capacitor on the board. Most bad capacitors will look like this: 18976c2.jpg
The other picture below shows a normal capacitor in the middle, but two bad capacitors on the sides of it. One with the dome top and one leaking. 5d53c3a.jpg
You can try repairing the board by replacing the capacitors or replace the whole power supply board. Most replacement boards can be found at a good price at Shopjimmy.com or Ebay.
Posted on Dec 29, 2009
dave1645
  • 834 Answers
SOURCE: My sanyo DP32649 tv screen has went black and wont
do you have sound? if so check for a bad cap in the power or mainboard the can like device will be puffed up on the top the values is on the side if you find one change it out if not you will need a mainboad common problem
Posted on Nov 20, 2009
SOURCE: My Sanyo DP32649 Will not turn on. The green light
Sounds like the power supply is bad.Do you know anything about working on circuit boards ? I bet some of the capacitors need replacing.This is a quick and very cheap fix if you know how to do it.
On the back of the tv is a panel held by two screws.Remove those and you have instant access to the power supply.Look and see if any of the capacitors are bulging or leaking.
Posted on May 07, 2010
SOURCE: sanyo lcd tv model dp32649 when 1st powered up it
i have this same problem and it just started
Posted on Feb 15, 2011
Sanyo dp32649 on light comes on but know picture or sound what can I do to fix this ?
This is likely a power board failure. Check that this board has blown caps and replace the caps with the exact part and make. This is usually a $10 fix.
Jun 01, 2014 | Sanyo DP32649 31.5 in. TV
Keeps reseting itself
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Jan 01, 2014 | Sanyo Dp32640
The hatch wont stay up, makes a loud popping sound and comes down.
sound like the shocks that hold the hatch open have been over extended, thats what the popping sound is when its opened.. replace the shocks and that will keep the hatch open and eliminate the popping sound,
Nov 06, 2012 | 2010 Chevrolet Chevrolet Traverse LT
My Sanyo DP32649 Will not turn on. The green light turns on and off when I press the power button but that's it. there's no sound and the screen just stays black.
Mar 14, 2010 | Sanyo DP32649 31.5 in. TV
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Aug 08, 2009 | LG 47LC7DF 47 in. LCD HDTV
No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Jun 01, 2009 | RCA P61960 61" Rear Projection Television
Video warps on edges then cuts out to black, then fades back in
Please dont rate me if could not fix your problem. Check the tv lamp. If doest work well, replace it. Thank you..
Nov 29, 2008 | Samsung TXM3096WHF 30" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sanyo DP32649 31.5 in. TV Logo
106 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
