Question about Sony PVW-2650 VCR
Sony bvw 35
I am gettting a flashing error message everytime I put a tape get the tape out I need to turn off the unit hold in the eject button and turn on the unit...can I safely clean the inside tape path area myself any solutions and or suggestions
  • Anonymous Nov 13, 2008
Robairto- Do you recall what the error code is?
Posted on Oct 14, 2008
How to eject an HDCAM tape stuck in as BVW75 Beta deck.
I don't know what this error code means but I have managed to remove tapes which stuck in a VCR and cannot be ejected. Whether you do this is purely up to you, but it's usually possible to remove the casing (carefully!) so that you can get to the tape-handling section. Then it's a matter of gentle probing & trial and error to get the machine to release its hold on the tape. Look for a series of mechanically linked parts which are driven by motor but activated by a microswitch tripped by action of inserting the tape. Just don't strain the linkages and if you remove anything make a note of where it came from.
Apr 28, 2015 | Televison & Video
My jvc camcorder shows me a message that my unit is on safeguard mode
E04 is the only one that a consumer can try to rid. This error normally is the fault of a bad tape. I recommend removing battery and HOLD DOWN EJECT, while reconnecting battery so its the first command camera sees. if tapes eject, try a new tape.
Jul 22, 2014 | JVC Video Cameras
Everytime I put a cassette in my camcorder and close it, the eject light on the pull out screen flashes and C:31:23 flashes in the upper right hand corner of the screen
This is a mechanical error - it need to be torn apart and re-assemble the tape carriage to the transport. Do not force anything to avoid further damage. There can also be a bad sensor.
Jan 20, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
Mar 08, 2009 | Sony DSR-45P DV / Mini DV VCR
Error message C32:11 Sony Digital Handycam
Error 32:11 means, unloading mechanism time out. It is bit technical term.
its remedy is to remove battery / charger from camera and attache again and try to eject tape.
still no joy, let me know to help you more..
Dec 16, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Nov 26, 2008 | Sony Betacam SP Small Videocassette 30...
Jvc gr-dvx9 E04
The mechanism is out of sync, put a tape in and hold it, it wont go in but will try to open don't let it, remove the battery and reattach, let the tape eject, rinse and repeat 3 or 4 times and it will finally accept the tape.
Jan 08, 2008 | Video Cameras
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Sony PVW-2650 VCR Logo
277 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
