Question about Poulan Pro Gas BlowerVacuum ()
How do I install my vacuum attachments on my poulan Pro Blower Vacuum unit
2 Suggested Answers
boscia
  • 163 Answers
SOURCE: poulan pro elec blower/vacuum
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 30, 2008
My blower poulan pro BVM210 was running good and then just stop and cord got stuck. what`s wrong with it?
if your saying that motor was running then shut off and now the motor wont turn over with pull cord , then you might have a frozen motor , this mostly happens when one runs a two cycle engine on an improper fuel/oil mix , if this happend there is only a slim chance that engine can be saved by a qualified service tech , but there also is other reasons as well that an engine could freeze up , again a service tech would know for sure
Mar 10, 2015 | Poulan Pro BVM210VS 25CC Gas Leaf...
How do you get it to vacuum?
If you got all the parts you will find an adapter that fits over the air intake system for the blower. That is the vacuum source.
Jul 05, 2013 | Poulan Pro BVM200VS 25CC Gas Leaf Blower...
How do you adjust carbeurator mixture
There is a special tool with an internal star shape, part no. 530035560 availabe on the web if the dealer will not sell it to you.
Jul 07, 2012 | Poulan Pro BVM200VS 25CC Gas Leaf Blower...
How to attach vacuum mode on blowers
Brian, the black cover comes off/folds down and the large plastic tube mounts under this cover. The normal blower tube comes off and the elbow that the bag hooks to goes in its place.
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
How do I switch it from a vacuum to a blower, I would like to have an owner's manual.
"12a" doesn't come up as a Poulan model #, but you can download user manuals here:
http://www.poulan.com/node7925.aspx
Oct 06, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Have poulan pro gas blower,it is geting fire but will not start
spray carb cleaner in the carb with throttle at full then hold the throttle wide open for three pulls, if it doeasn't start remove air cleaner and put a finger over the carb hole and have an assistant or yourself pull the cord this may clear out the debree blocking the flow of gas otherwise the carb must be removed cleaned and the vacuum diaphram replaced.
Jul 15, 2009 | Poulan Featherlite Gas Blower, with Low...
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Poulan Pro Gas BlowerVacuum () Logo
156 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
