Question about Vacuums
I got my Bonjour cookie factory out a few days ago to see if I could figure out how to use it and the instructions were not in the box. The style number is 53330. I looked at it and I can't figure out how to get the cookie designs to stay in place. Could you please share with me what I need to do. Thanks!
Hi there, wondered if you would be able to help me please? A few years ago when breadmaking was all the rage I purchased a cookworks machine, of course had one go and since then it has sat in its box in...
Here is a Scan posted on photobucket. There are 9 pages, click next to see all. Right click each to safe to a folder on your computer an enlarge if you need to. Link here to manual.
Jun 30, 2011 | Vacuums
Dirt Devil Deluxe Easy Steam Mop won't steam
Hi Slatts51 I am having the same problem it worked wonders the first time I used it, now its doing the same thing as yours, I can hear it gurgling and sometimes it will emit steam but hardly like before, I think I might be switching to a different steam mop I contacted the company now it will take a few days for someone to contact me back, go figure.
Apr 11, 2010 | Dirt Devil MCE4500 Vacuum
I bought Hoover Wind tunnel central vacuum 2 weeks ago from Costco. There are no instructions how to mount the metal canister to the garage wall. Brackets to mount to wall not supplied with the unit. How...
There is a hinged bracket for this unit which has a 5" bolt through it. It comes from CanaVac who manufactures under label. If you cannot find this large U shaped bracket on the body or in the bucket, either return to COSTO or call Canavac and explain. A used bracket from an old Canavac will fit, nothing else will. If Costco is sold out you will not likely get one through a Hoover service center since they just don't break and it is a newer body style for Hoover made under private label.. A Canavac dealer might have one around
FYI if you got this unit at $200 off you got good value, if you paid full price and need to wait for a bracket, shop around for a different brand. While the unit and tools are good , the Hoover power head is the Achilles heal on this package. If you use it more than an hour a week , you will wear it out within 3-5 years as it is their light duty head.
If you have the bracket , hang the unit on a double stud if possible or 3/4 plywood braced across two studs. Leave 24-36 inches slack in your low voltage wire at the motor and coil around a pencil or long philips screwdriver, making it phone cord style... your wife and neighbors will think you are a pro......
Post back if you need more info.
Oct 16, 2009 | Vacuums
Same problem removing the easy empty cup..
The dark gray plastic slide is separate from the Easy Empty Cup. Just slide the release tab all the way to open position, and then pull the Easy Empty Cup straight up. With a little effort, the cup will dislodge from the dark gray plastic platter.
Sep 08, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Need instructions how to use Hoover Steam Vac Spin Scrub. I borrowed it from my Sister and she left it with no instruction book or letting me know how to operate it. I put water & cleaner in top tank....
I did have a solution in just a few minutes. Someone responded with a solution that gave me the website where I could go and print the manual in pdf, so did that, and checking instructions I was able to clean my carpets and get the shampooer back to my sister later the same day. I really appreciated your site and help I got for my problem. I found it on google. Thanks again!
beeangels@comcast.net
Jun 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Need instruction manual
a few steps down in Google, I found the whole manual in adobe format! I only need the filter for vacuuming, so I'm in the clear---except that it won't spurt soapy water out...I just squirt it on with a spray-bottle and use the brush and suction from the cleaner. Sorta fixed the problem but I'm desperate to get on with cleaning this very small area (an RV)
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
I just bought a new dirt devil vacume today an there was no warranty card in the box to send back only instructions to use it.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783056
Generic problem for all Vacuums
I just bought a new
Posted by beckyspuppet on Jul 14, 2008
I just bought a new dirt devil vacuum today and there was no warranty card in the box to send back only instructions to use it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always call the Royal factory and they can send you out a warranty card or the cust serv dept can do it over the phone, you would need the brand name, Model # and serial # in order to register the factory warranty. Other wais as a rule you have a one year factory warranty with your customer receipt as proof of purchase or you can call the factory.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Black marks on carpet
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=706295
posted by carpetburner on Jun 25, 2008
While I was walking on the carpet, I noticed a couple of black marks. I figured it was on someone shoes. I was vacuum a couple of days later and stated noticing small black marks on the right side of the brush marks left in the carpet by the brushes. I tried to clean them and they don't come out. They are sort of like a scorched pinched place or something. I had the handyman take it apart and he found nothing stuck in it, belt was replaced not to long ago, and he said everything looked fine. The black marks are not on the belt side. Maybe a wheel is sticking? It all seems to roll, and turn ok.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. After reading your question, there are only a few things that could be causing the problem. It is very possible that the brushroll could be dirty, or install wrong, on the ends of the brushroll the gray bearing holders will state NEW and OLD and both of the bearing holders needs to be identical – meaning the 2 should say NEW / NEW or OLD / OLD, not new / old of which could be causing the problem. The average belt change should be done every 4 to 6 months for the best cleaning, and the extra belts are stored in a Ziploc bag in the refrigerator. If the wheels are spinning properly then it is not the wheels unless they are dirty and the can be cleaned just by popping them out of the bottom plate holder with a screwdriver and then clean them under the sink. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Go Ahead. Use Us.
Jun 25, 2008 | Oreck XL Ultra Bagged Upright Vacuum
I am wondering how I can clean the inside of my bissell spotlifter powerbrush hand held cleaner? I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49876&thid=506980
Posted by carriespets on Apr 12, 2008
I am wondering how I can clean the inside of my Bissell Spotlifter Powerbrush hand held cleaner. I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it comes apart or not so I can clean it. Can you help?
Normally on the Bissell Spotlifter Powerbrush the item will comes apart from the sides into 2 halves and then you can either clean out or blow out the inside of the
Bissell Spotlifter Powerbrush, also you can take a wire coat hanger and straighten it out and bend a hook @ the end of the wire hanger and you can use the hook to pull out the clog or whatever is blocking the opening and you can also use a blower or an old tooth brush to clean the motor or to brush it off.
Always, check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 12, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Vacuums Logo
253 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
