In one of my usb prorts the black thing in the middle of it is broke off. When I insert a mouse or any other usb device in the other port area it cannot find new hardware. I really would appreciate an explanation and would want to know if there is a solution to my problem. I really need to use one port or the other.
    Sniper:
  • 72 Answers
It sounds like all the ports are using the same connection from your motherboard, and is causing a short circuit stopping other ports working correctly. I'm afriad you may need to take the computer to a competant repair engineer, as the motherboard may need replacing. This is only a educated guess of course, with out seeing the fault in action I cannot be 100% certain.
Posted on Oct 16, 2010
I cannot not get my small wireless logitech mouse to work again on my netbook after taking it out and inserting it again.
Try a wired mouse or another USB device to see if the USB port has been damaged. Try a USB phone charger cable to see if there is power from the USB port.
If the USB port is working for other devices then try your wireless stick on another PC.
Sep 28, 2017 | Logitech Cordless Mouse
My 10 inch netbook wont recognize new hardware(wireless mouse through usb port
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top bottom
or you might use the safe mode option
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red X right update driver
hope this helps
Nov 20, 2011 | eMachines eM250-1915 Netbook
My computer wont recognize new wireless mouse
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top or bottom also you might try safe mode
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
hope this helps
Nov 20, 2011 | Computers & Internet
My usb ports suddenly stop working...i plug and unplug my mouse and it works for seconds...then again stops...and again and again and again the same thing...
make sure the battery is good ((has full charge))also you make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) or if its a lead
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable)) if this fails to fix the problem you could try it in safe mode
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps
Aug 04, 2011 | ASUS M2N-Plus SLI Vista Edition...
Xp usb mouse not detected
hope this helps
Jul 29, 2011 | Gigabyte GA-K8VM800M Motherboard
My laptop cannot detect the mouse. It states that there is an undetectable device. I have followed all directions and I still can't get the mouse to connect to my laptop
I think this will help.
A USB Connector has 4 terminals.The two terminals at the ends are to supply 5 Volts. The middle two are for data transfer.
If the terminals at the end are OK the device will get power (5V). Then the computer can detect something was attached. But if one of the middle terminals are damaged, your computer cannot recognize the device.
The problem might be with the USB port of the printer. Connect it to a different port. Does it (mouse) work on your desktop machine? Then the problem is not with the mouse.
If the mouse fails on all USB ports, the problem is with the mouse. Check the USB jack of the mouse. Sometimes the damage is visible. Or else one of the 4 wires of the mouse cable is disconnected (damaged) due to bending of the wire. In this case, buy a new mouse or replace the mouse cable.
Jul 22, 2011 | Office Equipment & Supplies
Logitech wirless mouse light on top but not bottom and does not work...put in new batteries...still does not work
make sure the usb device is inserted correctly into your computers usb slot you might have remove it restart your computer then reinsert it or you might go for safe mode
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
Jul 16, 2011 | Computers & Internet
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
I just bought a new mouse for my laptop. It is a Targus Kaleidoscope Optical Mouse. For my HP Pavilion dv2700, I plugged it in and it will not work,it did install itself several times.Everytime I plugged...
First thing you need to do is to know that the USB ports of your laptop is really working. Insert another usb devices or storage such a flash disk. If the flash disk being inserted is not recognized by the system then the usb port you had inserted is malfunctioning or it is defective. But if the other usb devices like the flash disk is working then your new bought mouse is defective. Try to plug the usb mouse to the other ports available in your laptop.
Oct 29, 2009 | Targus Kaleidoscope Optical Retractable...
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
