Question about Samsung PCL6215R 62" Rear Projection Television
Thank You!! Hi, Just wanted to THANK YOU for your support with fixing my TV.. Installed these STK's and the TV works like a charm!! Saved myself a TON of $$ as well. A co-worker has a projection TV with the same issues.. He is going to see about fixing these STK's (if he has them) as well and see what happens.. Thanks Again!!
  • Samsung Master
  • 8,617 Answers
Youre welcome. If you need any more assistance please let me know.
Posted on Jun 04, 2008
My phillips projection tv model 60pp93 5217 has power going to it but will not turn on
Hi, thank you for visit fixya.
This kind tv is a trouble set.
3 possilbes solutions:
1.- SSB ( small signal board)
2.- Fly back ( high volts transformer)
3.- Convergence STK IC's ( stk 392-110).
I recommeded visit a near tv shop and request a estimate repair tv.
I am sorry if Am no clear about your tv solution, but, Honestly; Philips TV is a little hard for repair.
Any question I will be here. Thank you
Oct 02, 2009 | Philips 60PP9352 60" Rear Projection...
Tip
I gotta tell you...oh boy... you saved me a bunch of money. Right now the U.S....
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Jan 15, 2009 | RCA R52WH73 Projection Television
The tv "panasonic Cinemia Vision" does not turn on
Hi, thank you for visit fix ya.
Common problem on this tv.
Replace STK 392-110 . Use stk 392-150 ( better).
For parts, go to:
http://www.encompassparts.com/
Thank you
Jul 21, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problems on a 50HDX82 tv
You don't need the schematic...JUST LOOK for the STK392-110 or any STK 392 or STK 391 amp on VERY LARGE heatsinks...
They're not Teeny....They're not Weenie...
They're LARGE! Burn your Hand-oh Gigant-oh....
So get your screwdriver out and look for the largest, hottest heatsinks paired together...
Yes, you will be looking for TWO sinks the same size...
Apr 02, 2009 | Toshiba 50HDX82 50" Rear Projection...
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Hitachi projection
These ICs run about $20 each. If you can solder, you can replace them. Make sure that you use plenty of heatsink compound on the backs of these when you mount them. This is the white stuff between the STK and the heatsink.
Good luck and keep us posted.
Dan
May 12, 2008 | Televison & Video
Stk divergent chips
That series usually used the STK 392-110.
It has been upgraded to the STK 392-180. 2 of them.
Mr Bob
www.imageperfection.com
May 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Samsung PCL6215R 62" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
