Question about Whirlpool GEW9250 Electric Dryer
Clothes don't get dry
The dryer is about 1 year old, we just moved and I hooked it up, it turns on but the clothes don't get dry. I hear the heat come on, but it seems like it goes on and off to much. Shouldn't the heat stand on. Thanks
    Genius:
  • 1,028 Answers
Ckd rear vent hose be sure it is not flat and kinked try a load with vent disconnected if works ok ck vent all the way to the outside for blockage
Posted on Jun 04, 2008
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Dryer is not heating.
you need to return it from the seller
Mar 27, 2012 | Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 17, 2009 | Zanussi TC7114W Electric Dryer
Clothes won't dry
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
