Question about Baby Trend Expedition LE Jogger
Front tray how do you get the front tray off?
It is hooked onto the main frame of the stroller. Stand in front of the tray and reach to the side where it connects with the frame. There should be an edge that goes over the frame from the tray - pull on on that to detach it.
Posted on Aug 16, 2008
My Sony DVD DVP-NS508P keeps saying tray locked, I've every method nothing is working..are there other quicker ways to unlock it? my name is Nelly
Hi nelly? Yes. open the top cover by un screwing all the screws. Care fully disconnect all cables that connect to the motherboard from the tray. Un screw the 4 screws from the main unit to release the tray. If the tray wont come off, un screw the front panel from the main unit and look for some locks on the side. Unlock the locks and pull the tray plus front panel out. Turn the tray upside down and on the left side near the top of the tray, check for a gear. Try to move the gear in the direction that it is moving without forcing it and gently the tray will open. Once it opens, unlock the front cover attached to the tray to be able to have the tray on its own without the front panel. Check if a black rubber band that drives the tray is working or has lost elasticity and also check if the load motor is in good working condition. If any of the two has an issue, just replace and your dvd is good to go.
Oct 03, 2016 | Sony Televison & Video
Tip
How can you access the rubber belt when the tray is closed? I Can't ! I had the...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on May 02, 2009 | Samsung DVD-V4600 DVD Player/VCR
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
How do I remove paper tray
Instructions
Grasp the front of the output tray located beneath the control panel. Remove the output tray by lifting the front of the tray up and pulling the tray out. Set the output tray aside.
Read more: How to Load Paper into an HP Officejet All-in-One Printer ' eHow.com http://www.ehow.com/how_4489317_load-paper-hp-officejet-allinone.html#ixzz2NjlQ4lhl
Mar 16, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
Where is located paper tray number 1 and paper tray number 2?
Tray 1 paper is the major tray located down the base, while tray two you have to open the door of the printer.
May 10, 2012 | HP LaserJet P4015n Monochrome Laser...
How to remove drip tray
Hi
Lift up on the front of the drip tray and pull out the front. There are 2 locking pins on the bottom of the drip tray that lock into the machine, that is why you lift up on the front of the drip tray before you pull out.
Apr 20, 2010 | Saeco Royal Cappuccino Espresso Machine
I would like to print from the front casette, but the printer prints from the rear tray only. There is no command to switch to the front casette.
In the "print " dialog box choose "print preferences" then click "paper source" choose the correct tray. It varies depending on the model but the front tray is usually #1 tray.
Jan 08, 2010 | Canon Office Equipment & Supplies
Oki B4600 ONLY prints to rear tray - how to print to front?
Yes. click on your printer icon. select properties then look for Tray or Output Tray or Tray settings and change it
Jul 08, 2009 | OKI B4600 Laser Printer
Leaking from Detergent tray
TAKE THE DETERGENT TRAY OUT AND CLEAN IT.
IF THE PROBLEM PERSISTS TURN THE WATER DOWN TO A DRIBBLE AND SEE IF THIS FIXS THE FAULT. IF IT DOES--- THE WATER IS SPLASHING UP THE FRONT OF THE TRAY AND OVER THE TOP.
1) TAKE THE TRAY OUT 2) LOOKING AT THE TOP OF THE CAVITY ,COUNT BACK 4 ROWS OF HOLES, DRIILL THEM OUT TO 1/4 INCH . 3) BLOCK THE FIRST 3 ROWS OF HOLES WITH SILSATIC.
IF THE SLOW FILL DOES NOT FIX THE PROBLEM TAKE THE 2 SCREWS OUT OF THE BACK AND SLIDE THE TOP OFF, YOU WILL THEN BE ABLE TO SEE THE DISPENSER AND THE HOSES GOING TO IT. THEY MAY BE DAMAGED.
Jul 06, 2009 | LG WM-2277HW Front Load Washer
It says to load paper in the MP tray
Pull down the front cover where it says Brother, the manual feed input is behind that panel (above the main input tray)
Nov 19, 2008 | Office Equipment & Supplies
Baby Trend Expedition LE Jogger Logo
168 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
