Question about Stairmaster Stepmill 7000 Pt
I have a Stairmaster 7000 PT. Just moved from one room to another. When disconnecting the display one of the wires in the harness slid out. I tried to put it back in the connector where I thought it was. In any case I have a Green like on the transformer with a dead display.
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Posted on Mar 14, 2010
Stepmill 7000 PT cs com error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is a communication error. Start by confirming continuity in the wiring harness. The following link will show how to use a multimeter.
Video about Multimeter Testing
Nov 21, 2013 | Stairmaster Stepmill 7000 Pt
My Stairmaster 7000PT has no resistance past level 10 or 11?
This could be caused by worn alternator brushes. The following link will take you to a video on testing the alternator. If the alternator checks out, you may be dealing with a faulty display console.
Video about Performing Jumper Test on Stairmaster Alternator
Feb 06, 2013 | Stairmaster Stepmill 7000 Pt
My stairmaster 7000 pt has no resistance
I would suggest checking the brushes in your alternator. The alternator is the component that provides the resistance in this unit.
Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
Nov 29, 2012 | Stairmaster Stepmill 7000 Pt
I have problem with master console of step mill 7000 pt stair master
If you have a Stairmaster Stepmill 7000PT that has an older style console with the red LEDs and you want to upgrade to the newer, console with the blue LCD; the parts necessary for this upgrade include the console and the console cable.
Stairmaster Stepmill 7000PT Console Upgrade
C40 Console Repair Video for Stairmaster Steppers
Oct 19, 2010 | Stairmaster Stepmill 7000 Pt
I need the configuration code for a stairmaster 7000 pt. it just says config req. It has done it before but I cant find the code again. do yo know the code?
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Aug 11, 2010 | Stairmaster Stepmill 7000 Pt
7000 PT will not start up (display flashes)
On that relay board their should be 2 lights engaged:
1.power 2.relay.
It sound like a loose connections there are 3 connections to the board first that I would look is the power connections to see if their is no broken wires, than the connector that goes to the display that may have exposed wires that may be grounding out on the frame and by jostling the connectors and see if either one stops the light flickering and relay clicking.Their can be also cold soldier connection on the relay board. Hope this helps
Feb 11, 2010 | Stairmaster Stepmill 7000 Pt
Breaker keeps tripping on the machine
Open the right side panel and look at the wiring coming through from the bottom outside panel. Move the stairs by hand and see if the corner of the stair touches the wires coming through the from the bottom panel. If so your chains have stretched and need to be adjusted. The wire harness will also need to be replaced.
Apr 28, 2009 | Stairmaster Stepmill 7000 Pt
Stairmaster Stepmill 7000 Pt Logo
35 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
