Question about Acer Aspire 9300 Notebook
Acer Aspire 9303WSMi - 17" LCD Screen is showing coloured static..
Screen is showing coloured static - If hooked up to external monitor is fine - AVG full system scan in safe mode reports one (1X) error on C: boot sector. Not sure if this is connected.
The system sits on a desk 27/7 & has not received any knocks or impact since new. The Warranty expired two weeks ago! :/
I can run the System through a 2nd monitor but would prefer to get the screen working again! It displays colours & static but no solid picture. The back light is fully functional.
Perhaps the hinge/connection?
Any help appreciated :D
Dir sir i have acer laptop moddel No aspire 9303wsmi
mfg.date: 070226
now my laptop matherboard not working and not showing display
after the press start button the prosser fan runing for a while and stop no show any display on the screen plese send me the mother board diagram for finding a fault and fixing it
buttshafaqat@hotmail.com
Posted on Aug 28, 2011
  • 458 Answers
More like the LCD Inverter Board..a loose connection would not cause that, unless you pulled the video cable by openening and closing the lid, but again that too is highly unlikely..
Posted on Jun 03, 2008
My Netbook Acer Aspire One will not hook up to the LCD projector.
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jul 24, 2012 | Acer Aspire One Netbook 8.9" Notebook
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
Vertical Red Line down the screen of my Acer Al1717.
Try hooking an external monitor. If it will still show on the other display, possibly it is a video card problem. But I highly doubt it. Usually for this issue, it will have a good display on an external monitor. Try if it will still appear n the BIOS page. Press F2 several times immediately after turning the computer on. If problem still shows there, then it is the LCD that is causing it to happen. You need to replace the LCD.
Sep 21, 2010 | Acer 17" AL1717 Flat Panel Color LCD...
Power ok.screen dark.nothing
To test and see if your LCD went bad you can hook up your laptop to an external monitor. If it displays fine on the external then your have a bad LCD or LCD cable.
If it does then the video card on the motherboard is bad.
Apr 15, 2010 | Acer Aspire 1690 Notebook
My Acer Aspire 1681WLMi's monitor does not work, LED showed the functional hard disk is also not light up, help me.......!!!!!!!!!!
May be the LCD screen is not working fine. Try to put external monitor with the laptop and see if you are getting display on it.. It will make you sure that the driver is fine...
Aug 30, 2009 | Acer Aspire 1681WLMi Notebook
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Jun 07, 2009 | Acer Aspire 5100 Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
External monitor with acer aspire 5520
Ok, first, as for your hard drive, 9 times out of 10 your hard drive is fine if you don't hear a clicking noise. Also have you try-ed plugging in your s-video cable to the monitor or vga cable to the screen? after you turn on the laptop with the power on? I can help you with hooking up you laptop to the monitor, just drop me your e-mail address.
Have a nice day!
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
THE LCD SCREEN ON OUR ACER ASPIRE 5520 IS CRACKED, HOW DO WE HOOK IT UP TO AN EXTERNAL MONITOR SO WE CAN STILL USE IT UNITL WE FIX THE SCREEN
Connect a monitor to connector 2 or 3
Hold down the Fn key and press F5. This toggles between laptop screen and the external monitor.
Acer Aspire 9300 Notebook Logo
480 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
