Question about Air Tools & Compressors
I have a TT ASEA Motor MT 100 lb 28 -4 NK 111118-E 66 The problem is that it was taken out of a car lift with the wires in the connection box disconnected and left unmarked. Can i get a diagram anywhere. Tom
  • 509 Answers
SOURCE: I have a viking 10 hp three phase motor brand new
If your wiring the motor for low voltage you have it correct. If you want high voltage I can post a diagram.
Posted on Mar 13, 2010
  • 3 Answers
SOURCE: electrolux 2100 canister vacuum
Open the door to remove the bag. Pull the side bumpers forward when the door is open. The profile of the edge of the top and the bottom of the vacum body is a "L" shape. The cross section of the bumper is a "I" and that holds the body together. Carefully lift up the top just a little to free the plastic end cap that conceals the cord spool. There are two plastic pins on the top and bottom that hold this piece on and they frequently get broken. (If that happens repair shops drill and hole and insert a screw.)
There is a plastic protector plate that lifts up on either end and then is slid about 1/8th inch clockwise and then up.
Copy the wiring pattern on the four male connectors on the motor and the wire spool.
Post your wiring diagram and it will solve a lot of people's problem trying to reassemble this machine's -- including mine.
Posted on Jan 07, 2008
SOURCE: ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour called around and he popped the right wire in the right place and we were in business. Not sure what he did and he is not sure either. Thankyou Wal.
Posted on Nov 16, 2008
E61N
  • 515 Answers
SOURCE: TomTom One Xl device not connected
Try this:
http://www.tomtom.com/support/index.php?Language=1&query=connect+to+home&FID=7375
Posted on Apr 17, 2009
roadrunning1
  • 152 Answers
SOURCE: wiring diagram for thermo king street boss
need the model number for this one
Posted on May 10, 2009
I have a TT ASEA Motor MT 100 lb 28 -4,anybody have a wireing diagram ?most of the wires are disconnected.
you can check at the given link drop your mail id they will answear but you have to pay for diagram http://toolsnyou.com/
Dec 14, 2017 | Cars & Trucks
1995 Dodgestealth my car just started feeling like she's not in sync with mt changing the gears and she has cut off and wouldn't start back up for a second just had dodge lift the motor alittl
Your not making sense to me
Your talking the manual transmission
being related to something else
Work on the shutting off & no start problem
Take it back to the dealer
I was just there,why wasn't all that taken care of?
Mar 08, 2013 | Cars & Trucks
Oil pan repl. 1995 ford ranger 3 liter automatic
Oil Pan, Ranger SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Engine Lifting Sling 014-00036
Removal
  1. Disconnect battery ground cable. For additional information, refer to Section 14-01.
  1. Remove air cleaner outlet tube assembly by unclipping air cleaner clamp, loosening hose clamp at outlet tube, disconnecting intake air temperature (IAT) sensor and mass air flow (MAF) sensor connectors, and crankcase ventilation hose.
  1. Remove oil level indicator fan shroud retaining bolts. Position shroud over fan blade.
  1. Remove radiator support bolts. Raise and secure radiator to front core support.
  1. Remove engine mount nuts from studs.
  1. Unclip 42-pin connector from bracket and position it aside.
  1. Install suitable lifting brackets to left and right exhaust manifolds. Attach Rotunda Engine Lifting Sling 014-00036 (or equivalent) to lifting brackets. With a suitable lifting device raise engine approximately 50.8 mm (2 in). Install wood blocks between engine mounts and support brackets. Remove lifting device.
  1. Raise vehicle on hoist. For additional information, refer to Section 00-02.
  1. Drain the oil.
  1. Remove transmission insulator retaining nuts and install a jack stand to extension housing. Raise transmission about 25.4-101.6mm (1-4 in) to gain access for removal of oil pan.
  1. Remove transmission inspection cover.
  1. Remove starter motor splash shield.
  1. Remove starter motor retaining bolts and secure starter aside.
  1. If equipped, disconnect and remove low oil level sensor.
  1. NOTE: Oil pan fits tightly between transmission spacer plate and oil pump pickup tube. Use care when removing pan to avoid damaging either part.
    Remove oil pan bolts and lower pan.
  1. Remove oil pump retaining bolts. Lower and twist pump to allow the oil pan to lower completely. Remove the pump and pan assembly from vehicle.
  1. Remove and discard oil pan gasket.
  1. Clean the oil pan mating surface.
Installation
  1. NOTE: When using silicone rubber sealer, assembly should occur within 15 minutes after sealer application. After this time, the sealer may start to set up, and its sealing effectiveness could be reduced.
    Apply a 4.0-6.0 mm (1/5 inch) bead of Silicone Rubber D6AZ-19562-AA or -BA (or equivalent meeting Ford specifications ESB-M4G92-A and ESE-M4G195-A) to junction of rear main bearing cap and cylinder block and to junction of front cover assembly and cylinder block. Position oil pan gasket to cylinder block and secure it with Gasket and Trim Adhesive D7AZ-19B508-B (or equivalent meeting Ford specifications ESR-M11P17-A and ESE-M2G52-A).
  1. Install oil pump assembly and bolt. Tighten bolt to 40-55 Nm (30-40 lb-ft).
  1. NOTE: If oil pan is replaced with a new pan you must tighten new pan to spec then loosen and retighten.
    Position oil pan to cylinder block and install oil pan to engine bolts. Tighten bolts to 10-14 Nm (7-10 lb-ft).
  1. Remove jack stand and install transmission insulator retaining nuts. Tighten nuts to 85-118 Nm (63-87 lb-ft).
  1. NOTE: When replacing low oil level sensor, use a new metal gasket with a rubber O-ring.
    Install low oil level sensor. Tighten sensor to 20-34 Nm (15-25 lb-ft).
  1. Install transmission inspection cover and retaining bolts. Tighten bolts to 10-14 Nm (7-10 lb-ft).
  1. Install starter motor and bolts. Tighten bolts to 22-28 Nm (17-20 lb-ft).
  1. Securely install starter motor splash shield.
  1. Lower vehicle.
  1. Install lifting device and support engine. Remove wood blocks and lower engine back into original position. Remove lifting device and Rotunda Engine Lifting Sling 014-00036 (or equivalent). Remove lifting brackets from right and left exhaust manifolds.
  1. Remove support straps, lower radiator into position, and install radiator bolts to core support. Position fan shroud and install the retaining bolts. Tighten bolts to 6-8 Nm (52-71 lb-in).
  1. Install engine mount nuts and tighten to 98-132 Nm (72-97 lb-ft).
  1. Connect 42-pin connector to the bracket and install oil level indicator.
  1. Install engine air cleaner outlet tube assembly. Connect IAT sensor, MAF sensor, and crankcase ventilation hose. Securely tighten the hose clamp.
  1. NOTE: When battery has been disconnected and reconnected, some abnormal drive symptoms can occur while powertrain control module (PCM) (12A650) relearns its adaptive strategy. Vehicle may need to be driven 16 km (10 miles) or more to relearn strategy.
    Connect battery ground cable.
  1. Fill crankcase with correct viscosity and amount of engine oil.
  1. Start engine and check for oil leaks.
    Oil Pan Installation - Ranger
    Hope this helps
Aug 14, 2011 | 1995 Ford Ranger Supercab
How do I change the starter?
first unhook the battery! then unbolt the cables from the back of the starter! be sure to mark them with masking tape, or something you can use to identify what wire goes where! then unbolt the starter bolts from the starter, and remove it! reverse this to put new starter back in!
Mar 04, 2011 | 1996 Ford Explorer
The starter on a 93 Ford Explorer, how do u take it out i have heard there is so many problem with taking it out and puting it back in
REMOVAL
  1. Disconnect the battery ground cable.
  2. Raise and support the vehicle.
  3. Disconnect starter cable and push-on connector from starter solenoid. CAUTION: When disconnecting hard-shell connector at S terminal, grasp the plastic shell and pull off. Do not pull on wire. Be careful to pull straight off to prevent damage to the connector and S terminal. If any part of the connection is damaged, replace the damaged components.
  4. Remove upper bolt.
  5. Remove lower bolt.
  6. Remove the starter motor from the vehicle.
INSTALLATION
  1. Position starter motor to engine and install upper and lower bolt finger-tight.
  2. Tighten the upper bolt to 22-28 Nm (16-21 Lb-Ft) .
  3. Tighten the lower bolt to 22-28 Nm (16-21 Lb-Ft) .
  4. Connect connector on starter solenoid. Be careful to push straight on and make sure connector locks in position with a notable click or detent.
  5. Install starter cable nut to terminal. Tighten to 11-13 Nm (91-122 Lb-In) .
  6. Replace red safety cap.
  7. Lower vehicle to floor.
  8. Connect battery ground cable. NOTE: When the Powertrain Control Module (PCM) is disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Sep 14, 2009 | 1993 Ford Explorer Limited
Need to replace the Stabilus lift o mat gas
Use a screwdriver to pull up/out the tab on the ends where they hook onto the ball. Then measure the length of the strut fully extended. That will give you the size. On my motorhome, I needed 100 lb struts on the doors. Your struts may have the lb printed on them.
Apr 15, 2009 | 2001 Volvo S60
I need a diagram of a 1995 ford escort engine
96 escort 1.9L
Engine Components
Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
(2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
(2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
(3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
Feb 24, 2009 | 1995 Ford Escort
Fuel pump relay
Located under the steering wheel. The fuse should be #28 and the relay will have 167 or 409 on it. Here is a link to a wire diagram for the TT
http://mk1tt.montebellopark.com/pdf/2002MYStdEquipWiring.pdf
Oct 19, 2008 | 2000 Audi TT
No fuel
Check fuse #28 and fuel relay has been a problem spot with the TT. Relay should be located in the mini panel under the steering column, relay #167 or 409. Try to reseat the relay. Here is a link to a TT wire diagram.
Next would be one of the 2 fuel pumps located under the back seat. There you will find the access covers to the sending units/fuel pumps.
Air Tools & Compressors Logo
1,055 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
