Question about Maytag Refrigerators
In the touch pad of my refrigeretor the light for the key symbol is on and said lock. i can't get no ice and the other ligths for the other symbol can not be turn on. I have a maytag modell #MDS2454FRW
  • WESLEY GRAHAM Oct 17, 2010
    Thannks vetteman that was very helpfull. Everyhing is fine now.
  • 712 Answers
This case will be well explained in your Manual, as it's a common source of error. Please read the User's Manual.
Posted on Oct 17, 2010
  • 2,299 Answers
There should be a lock button. You have to hold that button for 5-10 seconds.
Posted on Oct 16, 2010
Error code LOC ?
LOC means that the control lock has been engaged. (This feature also keeps a child from changing any setting when a load is in progress or starting the dryer with the cat in the unit.) On at least one Frigidaire dryer, press and hold the Options and Select touch pads for at least 10 seconds (until the display changes) to toggle the lock on and off.
Usually, the two keys to press for the Control Lock will have a line between them with a padlock symbol in the middle of the line. (This symbol will be in a very small font.) This may help you find the keys to press if other models of Frigidaire dryers use a different combination of touch pads.
I hope this helps.
Oct 24, 2013 | Frigidaire Electric Dryer
My touch pad on this laptop is locked what can i do to unlock?
hai:)
have you try fn + (function key), function key that have touchpad like symbol.
Jan 03, 2013 | HEWLETT-PACKARD ProBook 4520s Notebook
My refrigerator is not making ice and the control pad displays Er IF when i cut the power and put it again there is a small explotion in the dispenser.
HI,REPLACE THE ICE MAKER BLOWER MOTOR AND THE MAIN CONTROL BOARD,CHECK THE DISP IF THE EXPLOTION DAMAGE ANY PART..I ASUME THAT YOU OWN A LG OR SUNSUNG REFRIGERETOR WITH FRANCH DOORS..
Jul 05, 2011 | Refrigerators
Control Panel show: Refrigeretor temp panel = all ligths OFF Freezer temp panel = all ligths from 1-5 =OFF 6-7 = ON ??? Thanks
You have a problem with the freezer fan motor inside the freezer. It is not circulating cold air up to the refrigerator section. You will need to determine if the fan motor has failed or has frozen due to ice buildup. You will need to remove everything out of the freezer including the drawer assembly and remove the back wall panel to gain access to the freezer fan motor.
Jun 28, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have new ProBook 4720s and the touch pad is locked? How do I unlock it?
You will have a push button just above the touch pad, if you push that button it will activate the touch pad...
Alternatively you will have the touch pad symbol printed on one of the function keys (f1 to f12), if you presss the "fn" and corresponding function key it will activate the touch pad...
Feb 06, 2011 | HP Computers & Internet
When get to my home screen my cursor wont move when I move my finger on the mouse pad.
I'm assuming that you are using a laptop. If so, then look around for a button that locks out your touch pad from being recognized. Some laptops have the Touch pad "On\Off" button just above the touch pad. Other laptops will require you to do a key-combination to turn the touch pad On or Off. To do this typically requires you to press the FN or Function key while pressing one of the keys between F1 - F12. There should be a symbol\icon of a different color on whichever key it is that will give you an idea of what that key's function is. Every laptop is setup and arrange slightly different.
Aug 17, 2010 | Computers & Internet
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Ten key pad keys are turned on. How do i switch them off
Solution#1: Accidentally pressing Sft+Numlock key combination will activate & inactivates ten key pad. (You'll see light enabled in padlock symbol with a number in it [i.e.beside ALL CAPS symbol on your lap monitor]).
Use: "ShiftKey+NumLock" (NumbLock Key: 2nd panel from Top right on keyboard)
Jan 07, 2009 | IBM ThinkPad R51 Notebook
Refrigerators Logo
44 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
