Question about Samsung PCK5315RX TV
My pck5315r wont turn on and the power indicator wont turn on however when unplugging the tv it makes a click powering down kind of noise, what could the problem be?
    Brigadier General:
  • 8,909 Answers
You have a power supply fault. Look for short circuit diodes.
Posted on Oct 16, 2010
My Phillips 52" LCD TV won't turn on...it is just
it possibly you have shorted power supply board or inverter board that cause of clicking sounds..
try to unplug the inverter board then try again if the indicator lit in blue you have shorted inverter board that need to be replace.
Nov 06, 2012 | Televison & Video
Akai TV wont turn on right
this could be the power supply board
May 13, 2010 | Akai LCT2715 27 in. LCD Television
PS3 wont display video or audio
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Feb 11, 2010 | Sony Playstation 3 (PS3) Console
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Tv turns off doesn't come back on
it could be a power board problem but there are several causes for its shutdown. unless you have a background on electronic troubleshooting, you could try to fix it and find defective electronic component then replace them. if not you could just have it repaired by a reliable service area or person.
May 20, 2009 | Philips Magnavox 27MS343S 27" TV
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
Televison & Video Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
