Question about Solar Intermatic Ej351c Indoor Wall Switch Timer
The INTERMATIC MODEL EJ351 timer will not switch from "Manual" to "Automatic" mode, so I am unable to program it. The controlled light bulb has not burned out, but it will not switch to automatic mode by pressing the dial twice quickly as described in the user instructions.
SOURCE: can't find instructions
email me at rlehman123@comcast.net for a copy of the instructions
Posted on Feb 28, 2009
protek480
  • 1714 Answers
SOURCE: Describe your Intermatic &
Is the time clock rotating through the off tripper? If so, and the pump stays on, it's not wired right. Check the wiring at the clock for the pump.
Posted on Jul 02, 2009
SOURCE: Looking for the instruction manual for Leviton timer model 6651-I
6651 manual online here: http://www.smarthome-products.com/productspecs/DI-000-06651-22C.pdf
Posted on Mar 11, 2010
SOURCE: intermatic ej351, i ned the
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Posted on Sep 20, 2010
aquaman987
  • 927 Answers
SOURCE: We have the intermatic timer
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Rotate the time dial clockwise at least one click, stopping at
the half hour nearest to the present time.
NOTE: During programming, be careful not to press the
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
Press the dial once to set the present time. The Red indicator
light will go off.
Rotate the time dial clockwise to the first desired ON time.
The Red light will pulse momentarily with each click.
Press the dial once to enter the ON time. The light controlled
by the switch timer will turn ON.
Rotate the time dial clockwise to the desired OFF time.
Press the dial once to enter the OFF time. The light controlled
by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting.
Continue to rotate the time dial until the Red indicator light
comes ON and stays ON, indicating that the switch timer is in
AUTOMATIC mode.
Posted on Dec 03, 2010
EJ351 is programmed to work. In the on position the light it controls is on properly. in the automatic off position the light is on at approximately half intensity. When the manual control is in the o
This timer is rated for incandescent light bulb only.
With 40 watt minimum.
With 100' maximum distance between bulb and timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej351
EJ351 is not rated for CFL bulbs (or motors etc).
CFL bulbs are considered inductive loads (same as motors), while incandescent bulb is resistive load (same as a heating element).
Both types of loads use electricity differently.
Programmable wall timers are not ordinary on-off switch... unless you use the override switch.
... instead timers control electricity with electronic circuit board.
So when the manufacturer designs the electronics inside the timer, the design must anticipate how the electricity is used by the load.
Older designs like EJ351, and some modern timers, are not rated for CFL.
... however most newer timer designs are rated for both resistive and inductive loads.
Always read the specification sheet for load rating before installing programmable timer.
Nov 01, 2014 | Intermatic Programmable 24 Wall Switch...
The red indicator light for the intermatic light timer EJ351 does not even go on - what can I do?
Hello Barb.
EJ351 timer indicator light problem:
Reset timer and try again.
This timer is rated for incandescent lighting only, 500 watt max, 40 watt minimum, and timer has two wires.
When replacing switch, either wire can connect to timer wires.
Check circuit breaker: click breaker all the way off, and then back on.
Use non-contact voltage tester to see if wires are live at timer.
If the timer does not work, then it has 1 year limited warranty for defects in workmanship.
Copy following link for EJ351 timer manual with instructions for resetting timer.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Jul 18, 2012 | Intermatic Programmable 24 Wall Switch...
I have a intermatic ej351 in my garage to turn the outside coach lights on and off. I made the mistake of putting some 10 year bulbs in the coach lights and now the red light on the timer just flashes...
I answer questions for free.
I specialize in timers and electrical devices
Below is the manual for the EJ351
The red light is a good indicator of the EJ351 timer.
The manuals says that you can clear all programming by moving control lever to OFF-CLEAR position for 20 seconds.
After programs are cleared, the red light will turn off.
Then move control lever to ON position, and then red indicator light will start flashing.
So the problem may be that the timer programs were accidentally cleared.
Use the instruction manual to re-program your timer.
Add a comment if you need more assistance, and I will help.
Nov 02, 2010 | Intermatic Timer E1020, Single pole/single...
My intermatic switch won't turn off the outdoor lights. It covers the original light switch. It has a plastic cover with a extention that press smaller button underneath that says no op see inst. Please...
I specialize in timers.
According to Intermatic, they no longer make the light switch timer.
I cannot find the instruction manual on Intermatic.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
From my experience, I suspect that the timer is old and does not function any more.
If this is not correct, add a comment and I will answer
Hammacher makes a wall switch timer. $40
http://www.hammacher.com/Product/78709?promo=Electronics-Safety-Security&catid=106
Intermatic also makes another timer that is simple to operate.
It is called the EJ351 but it has to be wired into the wall.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
be3a610.jpgEJ351 cost $25 http://www.nextag.com/intermatic-timer-ej351/stores-html
Nov 01, 2010 | Hardware & Accessories
Didn't sve the instructions on how to program??? I have a model EJ351
The EJ351 instructions are posted on-line at Intermatic
Intermatic shows all their products and manuals on-line
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
The instructions are straightforward
If you have a problem, please re-post another question
Oct 20, 2010 | Intermatic Programmable 24 Wall Switch...
I have the Sentry - timer for my outside lights. One dial is for pm and one for am. The lights are not going on when I put the dial on 7:30 pm. I have to manually turn them on and then off in the morning,
Ginger,
It sounds like an older Intermatic timer
Does your timer look similar to this timer? EJ351
Here are the instructions for this timer:
Usually if the timer is still made, I can find a manual and piece together a solution... but I don't know this timer, and if it is malfunctioning ....
It may be time for a new timer > the EJ351 is inexpensive, simple to install (just 2 wires) and simple to program >>> one knob controls both AM-PM.
Oct 04, 2010 | Intermatic Programmable 24 Wall Switch...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
Sep 19, 2010 | Hardware & Accessories
Solar Intermatic Ej351c Indoor Wall Switch Timer Logo
472 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
