Question about Cycling
I don't know how to lower my seat on my bike.... its a huffy cedar falls 18'' mountain bike.
    Genius:
  • 1,788 Answers
All nuts and bolts are metric, so you need metric wrenches.
Posted on Oct 17, 2010
How do you lower the seat on a 26 inch huffy backwater with rust?
you might need to spray liquid wrench on it and let it soak in then try using a pipe wrench because it's not going to come out without a fight. make sure you don't bang wrench on frame or put a wrench on frame because it will damage it and make the bike unusable.
Jan 21, 2013 | Huffy Men Mountain Bike (26")
Adjust seat for 26mens huffy
If it is a hand latch, pull out raise seat then push latch back in. If it is a bolt, then using a 5mm hex wrench turn it counterclockwise until loose. Do not remove bolt completely. Pull up on seat to desired height. Tighten bolt via turning it clockwise until tight. If it a mountain bike then while the pedal is at the bottom of the stroke you should have a 25-30 degree bend in your leg. If it is a road bike then you should have a 15-20 degree bend in your leg. If you need help choosing the correct height then go to your local bike shop with your bike and ask them to move the seat to the correct height.
Jul 17, 2011 | Huffy Cycling
The back tire rubs against the frame only when I pedal. The tire wobbles a little bit while coasting, but appears to pull over to the frame while pedaling. Huffy Stonemountain 2 - 18 speed bicycle.
Either the wheel is mounted wrong, moving at the axle or the wheel is not straight true and strong (spoke tension issues). Look at it. Try to wiggle the wheel with your hand.
Use search engines for "how to" questions.
Jul 14, 2011 | Huffy Men Mountain Bike (26")
I have a dynacraft magna great divide 21 speed mountain bike and don't know how to use it. There was no owners manual. I don't know anything about using the gears, could you please help'
Bikes is bikes so ANY owers manual would ge tyou through the basics.
TRy Huffy's. http://www.huffy.com/Support/OwnersManuals.aspx
Then, using a search engine, ask any question like "how to shift a bicycle" and videos will appear instantly.
This doecument will teach you a whole bunch of stuff about techniques and strategy for road riding.
http://www.johnforester.com/BTEO/ECIL.pdf
Jul 03, 2011 | Cycling
I am trying to assemble my bike, Huffy Ladies' Savannah Road Bike and don't have full instructions in the manual how many inches is Huffy Ladies' Savannah Road Bike ? 24" or 26"
The only Savannah bike that Huffy lists is a 26" (700C Wheels) mountain bike. Some details are available here: http://www.huffy.com/Products/Product.aspx?pid=380'5'16 . Huffy has the assembly instructions available on their site: http://www.huffy.com/Support/BikeAssembly.aspx . The direct link to the manual is: http://www.huffy.com/ExternalLink.aspx?url=/pdf/ownersmanuals/b5cdef6e-94bb-4bfb-9996-832637c144b8.pdf .
I hope this helps. If you have a different Huffy bicycle, start here: http://www.huffy.com/Default.aspx .
May 27, 2011 | Cycling
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
Apr 04, 2010 | Huffy Alpine Men's 26-Inch Mountain Bike
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
