Question about Timex Watches
My wife has a "clock" that has a "glass dome"ver the clock face and four "gold colored balls" hanging on "poles" that rotate around a center shaft. This is battery operated. The battery for the CLOCK works well, but the ones for the rotating "balls", don't work! I checked it out and found; There are no "metal contacts" where the positive / negative ends of the batteries are supposed to be placed?? There is ONE battery for the clock itself, and TWO for the other functions. Do you have "parts" for the other functions (ie do you have the metal posts and springs for the unit? Also, there are no wires from the area too the "works"?? The model number is; MFG# TMX999 (made in China). This was given to my wife by a friend that was dying, and now she would like to get it working. Secondly; do you have a "manual" for the unit? Please advise! Barry Wood bwood@cpinternet.com 7473 Seville Road Saginaw, Mn. 55779 218-729-7590
  • 67 Answers
SOURCE: wall clock not working
If you are sure the hands are not touching as they pass, perhaps the minute hand and hour hand are binding together at the hub. Try this: Gently pull on the minute hand by gripping its hub with the nails of your finger and thumb. It should slide forward a little (or come off). Also the same for the hour hand, to ensure it is not binding on the face of the dial.
I don't know the particular clock, but if it has a SECONDS hand, this is often the one that needs to be freed.
If all the hands are free, all should be good. If it has a seconds hand and the clock stops when this hand is going "uphill", try a fresh battery. If this doesn't fix it, remove the seconds hand and use the clock without it. Or you could try to counterbalance the hand by adding a little weight to the opposite side... this could work, but as it increases the mass of the hand also, it still might be a problem.
Another way might be to shorten the seconds hand..!
Posted on Feb 22, 2008
SOURCE: I have an out-of-commission German-made Anniversary Clock
I had the same problem; I inherited a clock by that description with my office. I'm not sure if it would help you, but I was able to at least figure out the mechanics of the clock from this site: http://www.clockworks.com/cintro1.html
They claim that you can order the spring there.
Posted on Nov 29, 2009
cmcduncand
  • 714 Answers
SOURCE: forrestville mantle clock
RECOMENDATION:
Seek professional help.
For this question it will be hard to evaluate it from here.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on Mar 22, 2010
  • 299 Answers
SOURCE: I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Posted on Apr 15, 2010
  • 2501 Answers
SOURCE: I have a Expedition Metal Combo watch itme
If the watch is out of warranty, them speak to you local Timex service center (see "timex.com" for contact detals) and take advice from them.
Posted on Jul 01, 2010
The minute hand is loose and just rotates with the direction u move it.how do I fix it
Well, it is time for your lesson in "watch repair, 101."
Most all watches and clocks have the hands press on the various stems that stick out from the face.
There are usually 3.
The smallest diameter is also the longest, and is for the second hand. Next largest is between the middle shaft and the outer shaft, and is for the minutes.
The largest diameter shaft, usually the shortest, is the hour hand. Usually each hand presses on the correct shaft.
You'll likely need a magnifying class and a gentle touch.
God bless your efforts.
Dec 14, 2015 | Watches
Bulova mantel clock won't keep time. New batteries and will chime. It's about 25 years old at least.
Try CAREFULLY cleaning the mechanism with naphtha lighter fluid. Lighter fluid is high grade naphtha. Be careful not to allow it to run on to the face and electronics. It may damage the face with stain or remove any decals or cemented numerals. It may only take a small amount to clean the shaft bearings. The lighter fluid cleans and lubricates without leaving a film. If you can, while the fluid is on the gears, manually turn the clock forward 12 hours. That will rotate all the gears fully. Us the fluid sparingly!
Apr 14, 2011 | Bulova Watches
I HAVE A CLOCK MOVEMENT KIT 1/4 INCH . THERE ARE 4 PIECES AND NO INSTRUCTION ON WHAT ORDER THE HANDS ARE PLACED ONTO THE MOVEMENT MECHANISM
mcdevito75 here, I do some work on watches and clock movements are similar. Generally the face/dial; of the clock will go onto the movement and is secured onto the movement, then the smaller hand is pressed onto the shaft in the center of the face/dial Gently place the small hand onto the shaft, NOW with twezzers apply gentle but even pressure onto the small hand just where the small hand goes onto the shaft, NOW, Make sure the small hand is pointing exactly to any of the hour numbers, place the larger hand gently onto the shaft, make sure the larger hand is pointing to the 12 O"clock useing the twezzers again press the larger hand onto the shaft, gentle even pressure on the hand just where it goes onto the shaft, both hands should now be pointing to the exact hour you lined up . Turn the hands too make sure they line up exactly at different hours. 3 O'clock, 6 O'clock etc. --------- NOW the bad news, if you need to remove the hands for any reason, even pressure must be applied to keep from distorting the hands while removeing them and for this you"ll need a Hand remover tool available on ebay This hand remover tool slips just under the hand right where it attaches to the shaft, you could use anything to do this such as 2 needles, but evn pressure must be ued to pry up and remove the hands other wise the hole in the hand will be dis-torted. Good Luck.
Feb 11, 2011 | Watches
I do not know how to start the clock : Clock under glass. Has three balls supposed to swing. I replaced the battery.
Lift the glass and swing the pendulum/balls. Or you could, if it's small enough to hold in your hand, suddenly twist it, there by using inertia to swing the pendulum.
Aug 03, 2010 | Watches
Ca i put new clockworks in an old clock face - i have a vintage coffee pot clock with a light up perculator that i love- the clock no longer works-the light does- can i just buy a clock mechanism from a...
mcdevito75 here, If the old clock works are Quartz, you may not be able to get a new Quartz movement as it may not be made anymore, BEST BET, look for a small watch repair shop in your area, I'm sure they can do something.
Jul 11, 2010 | Watches
I have a Melodies in Motion Seiko clock that is about four years old. It still keeps great time. However the face movement sticks about half-way through it's movement. Any idea of how to repair the problem...
mcdevito75 here, Sounds like 1 or both hands are hanging up on themselves or something on the face of your watch, look for a small watch repair shop in your area, or check here at fixya, bottom of page, click on repair service directory the watches.
Jul 03, 2010 | Seiko Clocks Melodies In Motion QXM135BRH...
Forrestville mantle clock
RECOMENDATION:
GOTO:
r/ David
Mar 22, 2010 | Watches
Manual for rosra watch - man's - #8637G looking for how to use this watch? it is both silver and gold, with a gold face and 3 inner clocks on its face
Search on the internet for the manual, or if you cant find one, just ask me and I will try to find one for you!?☺
Oct 14, 2009 | Bulova Watch
Watches Logo
35 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
