Question about Belkin (F5D7231-4) Wireless Router
Flashing red modem. Model# f5d8326-4v2. Held reset down didn't work. I have gotten it to work by the hard line from comp to router and it worked but no more
    Sergeant:
  • 358 Answers
Ok here is your solution.
open belkin setup Page for a manually setup.
Connect the computer to one of the four gray ports on the back of the router.
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Log-in in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
you'r ready to configure your router manually.
if ISP is DFSL use a user name and password connection type PPOE
is IPS is Cable just clone mac address.
in both of this cases don't forget to power cycle modem and router to get connected
Posted on Oct 31, 2010
Power light flashing red on router
READ THIS AND PERFORM IT TO TRY TO RESET.IF THIS DONT WORK POWER OFF THE ROUTER AND THE MODEM FOR 20-30 SECS.THEN POWER ON:1ST-MODEM
2ND- THE ROUTER
Apr 10, 2012 | Computers & Internet
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
ONLY ONE OUT OF ABOUT 15 isatap NETWORK adapters is not working. could that be the reason computer can not connect to DSL LINE? THE GREEN LIGHT ON THE ROUTER IS FLASHING. WINDOWS CAN NOT LOAD DRIVERS...
Thank you for using FixYa
Yes that could be the reason you are not connecting, or your internet may be down. Do you have more than one computer? Are any other computers working? Have you tried to reset the modem, or at least power down and turn off the computer and the modem and then try again? Is there a router besides the modem? Did you reset the router?
Please include all this information on your next request,
I hope this was useful and please comment if this was helpful to you.
Apr 24, 2011 | HP Computers & Internet
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Routers modem light keeps flashing and booting me off line but when i hard wire computer to modem as i am now it works fine. changed cables and reset computer and modem
Flashing lights on a router are routine - they indicate connectivity and traffic.
Seems to me the simple answer here is stay connected by wire. Wire runs much faster than wireless. Wireless is 10 <> while wire is usually either 100 or 1000. If you have to have wireless, do a hard reset on your router and also reload the drivers. Check with the manufacturer for any soft or firmware grades they may offer. If you find a firmware upgrade - make sure you understand the instructions before you start. If you fail in this department, you will have to replace your router. Had you given a little more information on this, I could have done better with links and such.
Mar 03, 2010 | Computers & Internet
Im with talk talk broadband and have a bt homehub 2.0 wirless router. is there any way to reconfigure the router so that the internet can work?
I AM ON TALK TALK LAND LINE AND HAVE LOST MY B/B CONN THE MODEM SHOWS TWO GR LIGHTS AND ONE RED I HAVE DIS IT AND RECON IT AND PUSHED THE RESTART BUTTON BUT IT WILL NOT LOAD WHEN I CHECK CONN IT SHOWS RED CROSS BETWEEN COMP AND CONN
Nov 19, 2009 | Computers & Internet
Internet light is red
If you haven't done so already I would turn the netopia router off and back on again at least once. If that doesn't solve the problem it's probably a sync issue with your providers equipment. I'm assuming you're using ATT because of the Netopia router, but generally speaking you should contact your provider and have them run a line test.
They can determine if the line is good or not. If It is all working fine at the time you call ask them to run monitoring on the line for the following 24-48 hours to try and anticipate a reoccurrence. Insist that they call you back regardless at the end of the monitoring term to share their results with you.
Hope this helps.
MO
Hope this helps.
Jul 12, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
Not working
Go into your routers settings, usually by typing it's ip address in your web browser and save all the settings to your hard drive or make a note of all the settings. Look to the connections menu and see if your ISP's ip address and dns servers are showing and not showing noughts, if it does show noughts your isp is at fault, if there is dns server numbers showing,look to see if there is an option to restart the router, if restart it and try again. On the router normally at the rear there should be a hard reset button which should be held in for atleast 10 seconds and let the router reboot. If non of this works, then the router is probably faulty
Apr 21, 2007 | Actiontec GT704WG Wireless Router...
Belkin (F5D7231-4) Wireless Router Logo
100 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
