Question about Saeco Royal Professional Espresso Machine
The steam on my Royal Pro has been getting weaker over a period of time, I do still use it but its takes a little longer to froth. I don't think its a scale issue as I'm in Australia & nothing else appears to get scale. Could it be the pump & can I replace it? I am a licensed electrician, but no experience on coffee machines...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
The problem could be the building up of scales in the lines and boiler.It should be descaled after about 800 coffees been made.Is it water coming out of the steam arm freely? If water comes out good and the steam is weak means blockage in steam boiler and the lines.
If coffee comes out well means the pump is still good. You can replace the pump quite easily by yourself but make sure steam boiler and the tubes are cleaned.
Have a good day.
Posted on Oct 18, 2010
Testimonial: "Right on the money, already descaled & restored. Thanks!"
Steam is not strong on my ec702 delonghi. I have cleaned the wands. The wand spits out a lot of water with a strong steam, bu the steam gets weaker as I am trying to froth.
The steam temperature control (Thermostat) is not functioning.
The small quantity you get at the start is the steam pressure build up with hot water. Water steam cannot keep up the pressure.
Replace the steam thermostat.
Dec 24, 2016 | DeLonghi Coffee Makers & Espresso Machines
Not enough steam is produced to make good froth.
I have one too and what I do is: turn all 3 switches on and while I'm waiting for the "ready" light to come on I go ahead and pour the milk into my frothing pitcher and prep my espresso basket.
After the "ready" light comes on I install my espresso basket and turn the handle to the "left" so no liquid starts coming out.
Next, I take an empty coffee cup and hold it under the steam nozzle and start opening the steam valve until I get only steam instead of a stream of hot water. Once you have steam, close the valve, put your pitcher of milk under the steamer and froth as usual to around 150 degrees.
Jan 21, 2010 | Coffee Makers & Espresso Machines
Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
Jul 09, 2009 | Saeco Royal Professional Espresso Machine
Frother builds up too much pressure and explodes off the machine
I had the same problem. All you need to do is take the steam nozzle apart and clean it. I tip can be cleand with a neadle. Just make sure you unblock the little side holes and make sure to thoroughly clean the little hole in the front. Over time the milk builds up in the nozzle, clogging up the "steam holes", so the preassure gets too big and the rubber attachments can't hold it any longer. Hope that helps.
Jun 05, 2009 | Jura Capresso F8 Espresso Machine
Heat temp and time
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
The mahine does not froth the milk properly anymore
alisha165,
the saeco royal digital dosn't froth milk.... it produces steam, you are the one that froths the milk. is the machine still producing steam? if not you will need to have your steam boiler replaced. This should only be dune by a qualified repairer. If it is still producing steam but it is not as good as it use to be, descalling you machine may help.
Sep 29, 2008 | Saeco Royal Digital Plus Coffee...
Not enough steam for capuccinos
hello use a calcium remover put some in let it work rinse it good .no steam probably heater full of calcim you may have to clean it a few time before cheers
Jan 13, 2008 | Krups Bravo Plus 872 Espresso Machine
Steam not frothing properly (very weak output)
It can be the electric magnet valve that has to be replaced.
Aug 07, 2007 | La Pavoni Stove-top Espresso Maker...
Saeco Royal Professional Espresso Machine Logo
263 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
