Question about Tandberg Data 200/400GB 420LTO LTO2 ULTRIUM INT HH SCSI W/CART W/BKUP EXEC QS (00712880230025) Tape Drive
Tandberg LTO HH (LTO-3)
I have Installed Tandberg LTO HH (LTO-3) Tape Drive in windows 2003 server.I am planing to use Veritas backup exec 10.0.5484.6 for backup.While installing Veritas backup exec 10.0.5484.6 in windows 2003 server I am getting following warning....
"One or more device on the computer are not supportable** "
Device:Tape 0
This device is not supported**
Can any body provide me a solution for the same?
    Problem Solver:
  • 6 Answers
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Posted on Jul 15, 2008
After a full back-up was made, the tape stays in the drive
Click Start, then Run, type in services.msc and hit enter
Look for the Symantec (Veritas) backup Exec Tape engine service and stop it by right clicking it and hitting stop.
Eject the tape.
Restart the service.
Dec 17, 2009 | Veritas Backup Exec 10 for Windows Servers...
Certance DAT 72 tape drive stopped communicating with PC
We have had the same problems with HP drives and Veritas. In our case it was not the drive per se. While I am assuming that based on the date of your post that you have moved to another solution, however, I will provide for you what we did.
First shut all down, disconnect the tape drive from the scsi cable, then restart. Go into computer management and turn all your backup exec services from auto to manual. Now go to devices and do a rescan. Once this is done and you see no tape drive whatsoever in the devices shut down the server. Reconnect the scsi cable to the drive and restart.
Go back into computer management, back to devices and rescan for hardware changes. Do you see it? If so, good! Sometimes a re-seating of connectors will do that. On the other hand, it could also be a tape driver from Veritas that just doesn't work (my case), take the original driver cd that came with the unit and start that loading up. Can you see it now? Can you use windows backup to access the tape drive? Now go into services and start the services individually. Go into backup exec and see if you can read your tape. Go back to services and reset all services back to auto. If you ever have to reinstall/upgrade backup exec, think twice about using their drivers.
Nov 12, 2009 | Certance Internal DAT 72 (cd72lwh-s) DAT...
Sun L25 Tape Library
what drives are inside as these units can come in several configs. For all SCSI units the Adaptec 29320 is good for fiber the qlogic cards are my prefered cards.
Drivers are available from sun for the library and drives although you can sometimes use the standard windows drivers for many drives. (search for LTO as the tape drive manufacturer in win drivers for LTO) Although best to use sun drivers if at all possible.
Library comes up as a medium changer in device manager.
What backup software are you using? If Backup exec then the latest version already comes with their drivers built in
hope this helps
Aug 27, 2009 | Sun StorEdge L25 (SG-XLIBL25D-BASE) DLT...
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
New tape drive
Didn't realize i had to install a Veritas tape driver to allow Veritas to see the drive.
Mar 24, 2008 | Veritas Backup Exec 10 for Windows Servers...
Loading Media
Same problem with Backup Exec 10d and Superloader 3 LTO-3.
This is not my first problem with this Superloader. I think it is garbage and will likely be in the garbage very soon. Very expensive garbage unfortunately.
Mar 05, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
How to compress file in Veritas exec 10
Make sure that your tape drive is using Symantec drivers. to do this follow these steps.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 31, 2007 | Veritas Backup Exec 10 for Windows Servers...
My Tandberg LTO Drive isn't working with Veritas Backup Exec
When you say 'rolled back' did you use a system restore function? Do the backup logs say why they failed?
Sep 12, 2007 | Tandberg Data 420LTO LTO 2 Tape Drive
Tandberg Data 200/400GB 420LTO LTO2 ULTRIUM INT HH SCSI W/CART W/BKUP EXEC QS (00712880230025) Tape Drive Logo
809 people viewed this question
Top Tandberg Data Computers & Internet Experts
David Payne
David Payne
Are you a Tandberg Data Computer and Internet Expert? Answer questions, earn points and help others
