Question about Amana ATB1832AR Top Freezer Refrigerator
TZ21QL MODLE REFRIGERATAOR WILL NOT COOL ON ABUOT
TZ21QL MODLE REFRIGERATAOR WILL NOT COOL ON ABUOT 55 DEG. FREEZER HAS FROST ON BACK WALL
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Freezer is 0 deg but refrigerator only gets to 55 deg. fan is running in freezer but no airflow to frige.
The most likely reason their is no air flow into the refrig. is because the coil in the freezer where fan that blows air into the freshfood section is blocked up with frost because a part in automatic defrost system has failed and not defrosting the freezer coil so air can pass through it. This is what to check to see why its not defrosting;
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
oldtech2332_9.jpgoldtech2332_10.jpg-->
While these pictures are for a different brand ALL refrigerators are similar and may look some what different than your but will be similar enough to yours
Aug 17, 2011 | Kenmore Refrigerators
Freezer sides works, refridgerator side will not get cool, any quick fix, I am pretty adapt mechanically
There is a good chance that the evaporator on the refrigerator side is frosted up due to a faulty thermal fuse or sensor or both. Since these units have more than one evaporator, there is no damper to get stuck.
May 27, 2010 | Samsung RS2556 Side by Side Refrigerator
Model 106 56569400 - Freeze side appears to be Ok. Refrig side not cooling to set temp 37. Current temp is 55-60. Door appears to seal properly.
If you have heavy frost build up on the back wall of your freezer you have a defrost problem. One of three things. Defrost timer, Defrost T-stat or Defrost heater. Usually problem is with the T-stat. If no frost make sure the evap fan is blowing. You should be able to hear a fan noise when opening freezer. If no fan noise replace evap fan which is located half way up behind freezer wall. Good Luck
Jan 27, 2010 | Refrigerators
TOP FREEZER IS 20+DEG AND BOTTOM IS 54+ DEG. WHAT IS THE PROBLEM?
Probable fan problem in freezer . Would have prefered more information though . Is there frost on the rear wall of the freezer ? Are your coils clean under refrig ?
Jul 18, 2009 | GE Refrigerators
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge only cools to 55 deg F
check the bottom of Ref. see if it close right, sometimes the rubber near the bottom parts broken.
Jul 08, 2008 | KitchenAid KSRS25IL Side by Side...
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
Amana ATB1832AR Top Freezer Refrigerator Logo
109 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
