Question about Kodak EasyShare V570 Digital Camera
When I turn the camera on, the opening screen "Kodak EasyShare System" with logo appears briefly, then the camera shuts down. I tried charging the old battery, installing a new battery and taking the battery out pressing the on button for ten seconds and then petting the battery in and turning it on. This only results in the camera asking me to reset the time and date at which point the same opening screen appears and the camera shuts off again. Any suggestions?
  • jna1972 Oct 17, 2010
    okay! thanks for the advice.
    President:
  • 4,070 Answers
Hi! The circuit board is surely faulty and I strongly suggest that have a technician to look at it. He may replace some blown or faulty capacitors for it to work again. Hope this helps and thank you for using FixYa!
Posted on Oct 17, 2010
  • alectronik Oct 28, 2010
    By turning on, the camera checks if an "Over Current" occures. If some parts work hardly because of dirt or grain of sand, it will turn off in the first seconds. Problem can be the cover (9 gears in it) or the zoom (5 gears). It is´nt easy to open it and to remove the dirt.
    best regards
Kodak M863 charge ok checked battery is charged and tried new battery. Within one day battery is flat.
Go into settings, close wi fi and blue tooth. change screen brightness , change time on screen shut down.
Oct 29, 2014 | Kodak EasyShare M863 Digital Camera
My camera will not turn on, it is fully charged. When I turn it on it goes to the main Kodak screen and then just shuts off. I have tried cleaning the battery, but nothing has worked.
There is a systems control board failure or the systems control has detected a problem in the camera. I know you have fully charged your batteries, but try regular batteries just to be sure, because as the rechargeable batteries degrade the systems controller will shut the camera down.
Jan 13, 2011 | Kodak EasyShare M863 Digital Camera
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
Camera will not stay on
I have basically the same problem. I sent it in for repairs. It came back and I followed the instructions they came be. BUT IT STILL WONT WORK. it's worse then before, the logo wont even come anymore ! :(
Jul 18, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
May 28, 2009 | Kodak EasyShare Z700 Digital Camera
Camera won't stay turned on
Format the SD memory card.
Get the 5 volt charger and charge 3 hours.
Format the internal memory.
Menu button and change to power save.
Do not use the flash all the time.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EasyShare One lens won't open - camera cycles on/off
I had the same problem. Even though I was keeping the camera on the dock all of the time to charge it, the solution was very simple - get a new battery for inside the camera.
I bought new ones at a greatly reduced price on eBay. Now I carry one with me wherever I go in case the battery wears out/down.
I shoot a lot of videos, so it really takes a lot out of the batteries.
Dec 15, 2008 | Kodak EasyShare One Digital Camera
When I turn the camera on the following message appears- high camera temperature, camera will shut off. The camera is a Kodak easyShare Z710
Have Kodak Easyshare V1253 with same, "high temp.," error then shutdown. Kodak batt. showed 25% charged. Charged batt 100% & temp. error went away. Batt. internal shows camera if batt. too hot. Try new batt.
Sep 12, 2008 | Cameras
Surendran@pvti.org
Surendran, How many cameras do you have or you just works as camera's repairman ?!!!!
Aug 28, 2007 | Kodak EasyShare C340 Digital Camera
Kodak EasyShare V570 Digital Camera Logo
140 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
