Question about Kenmore Dryers
How do I replace the belt - Kenmore Dryers
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 17, 2010
Noise sounds like a belt, only makes it in park, neutral and drive
Squealing noises are either
* a worn or loose belt. replace the belt.
* an A/C belt idler bearing. Replace belt and idler.
* alternator bearing: replace the alternator.
* timing belt idler bearing(s). Replace the timing belt and all bearings (there's a full kit for this).
Oct 03, 2016 | 2005 Subaru Outback
How to change a belt on sewing machine
Google is your fried in such cases Mary :>) I can probably find you your manual if you give me the model number.
  • How to Replace a Sewing Machine Drive Belt - YouTube www.youtube.com/watch?v=8Voq7f5vT6E
    • BY SEARS PARTSDIRECT
    • 1 MIN
    • 23K VIEWS
    2015-04-23 · Video embedded · ... shows how to replace a broken drive belt in a sewing ... a broken drive belt in a sewing machine. ... to Replace a Sewing Machine Drive Belt
  • Brother Sewing Machine Diagram to Replace Belt ? ' Yahoo ... https://answers.yahoo.com/question/index?qid=20090426184749AAQ5W2y
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-26 · Best Answer: I am sure there are the diagrams you are looking for are online. ... After years of machine maintenance I would love to have a duplicate ...
  • Videos of how to change brother sewing machine belt bing.com/videos 2q==Click to view 43:10HD Brother PE770 repairs, motor belt.(Spanish Discription) YouTube zClick to view 1:00HD How to Replace a Sewing Machine Drive Belt YouTube 9k=Click to view 1:03:43 SINGER 95-1 BELT REPLACEMENT & RE-TIMING 081813 YouTube 2q==Click to view 1:42 How To Install Antique Singer Sewing Machine Belts YouTube See more videos of how to change brother sewing machine belt
  • Brother PE770 repairs, motor belt.(Spanish Discription ... www.youtube.com/watch?v=Cy-wNw8_kuU
    • BY VINCE J. ARCURI
    • 43 MIN
    • 25K VIEWS
    2013-05-19 · Video embedded · Brother PE770 repairs, motor belt. ... In this video I am showing how to access the machine's motor drive belt. ... Brother Sewing Machine ...
  • Can U Help Me Find A Diagram to Replace Sewing Machine ... https://answers.yahoo.com/question/index?qid=20090428210336AAvwslh
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-28 · Can U Help Me Find A Diagram to Replace Sewing Machine Belt ? ... I can get a Diagram that can show me how to replace a belt on a Brother Sewing Machine ...
  • Replace Belt ' Brother support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=mfcl8850... Replace Belt. Follow the steps ... Close the front cover of the machine. Reset the belt unit counter. Press (Settings). ... please contact Brother customer service:
  • How to Replace a Sewing Machine Belt ' eHow www.ehow.com > Crafts > Sewing & Textile Crafts > Sewing
    • BY RUTH O'NEIL
    How to Replace a Sewing Machine Belt ... When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; ...
  • Sewing Machine Belt Sizing - Sewing Parts Online ... www.sewingpartsonline.com > Home > Maintenance & Repair Home Maintenance & Repair Sewing Machine Belt Sizing. ... How to Replace Sewing Machine Gears December 5, 2010. How To Replace A Sewing Machine Motor May ...
  • Brother Sewing Machines and Accessories: Rubber Drive Belt https://www.brothermachines.com/sewing/491/Rubber_Drive_Belt Brother sewing machines, parts and accessories ... Brother Emb. Cards; ... Home Sewing Machine Rubber Drive Belt
  • Sewing Machine Belt - Sew-Classic shop.sew-classic.com/Belts_c3.htm Click here to download for FREE How to determine the correct belt size and how to adjust/install a sewing machine belt. ... Sewing machine motor belt ... Brother Elna ...
  • Sewing Machine Repair Tips: Change / Replace The Belt on a ... sewingmachinerepair.blogspot.com/2008/01/change-replace-belt-on... 2008-01-27 · Although it may initially look complicated to change the long leather belt on a ... brother sewing machines. April 27 ... cover over the belt on the sewing ...
  • http://www.bing.com/search?q=How+to+change+brother+sewing+machine+belt+&qs=n&form=QBRE&pq=how+to+change+brother+sewing+machine+belt+&sc=0-42&sp=-1&sk=&cvid=B1D6E61981414EB7A56CB3A4C0D371A3
    Jun 18, 2016 | Brother Sewing Machines
    If I replace timing belt 97 quest van do I need to replace camshaft belt tensioner
    any time a vehicle has a hydraulic tensioner it should be replaced. most parts stores have a timing belt replacement kit. some have the idler pullies and the tensioner and belt. you should replace the water pump while you are in their.
    Sep 08, 2014 | Vehicle Parts & Accessories
    Belt keeps slipping on treadmill and belt is all the way back
    If you have adjusted the tension on your belt to the max, it is more than likely time to replace your running belt. The running belt naturally stretches over time. I would suggest replacing the belt and flipping your deck. If the deck has already been flipped once, then you would need to replace the deck as well. Life Fitness Treadmill Belt and Deck Replacement Video 95T
    Apr 01, 2014 | Life Fitness 91Ti Treadmill
    My serpentine belt went how do i change the belt do i need a special tool
    Identify which belts need to be replaced. If you are replacing the air conditioner belt, you may need to remove the alternator belt because of the way the belts are shared on the crankshaft pulley. As a result, some mechanics recommend replacing both belts together.
  • Step 2 Loosen the lock bolt for the belt you are replacing using owner's documentation. The lock bolt will be near the belt tensioner component.
  • Step 3 Turn the adjustment bolt to change tension on the belt. When the belt is loose enough, slip it off.
  • Step 4 Use your memory or a belt routing diagram to install the new belt on all pulleys.
  • Step 5 Adjust the adjustment bolt to replace tension on the belt. Tighten the lock bolt.
  • Step 6 Make sure the belt is correctly seated on all pulleys and that the ribs fit into grooves on the pulleys.
  • Step 7 Run the engine and check for any flapping or looseness that could indicate incorrect installation.
  • This was copied from the service manual.
  • Jan 24, 2010 | 1995 Dodge Intrepid
    How often should you get engine belts replaced and what belts need to be replaced?
    Replace belts as needed, check for cracks on the sides of the belts or pieces missing from belt. A good belt should last 100,000 miles. and it is a good practice to replace at 100,000 even if it looks good. REPLACE ALL BELTS as needed.
    Jan 18, 2010 | 1996 Nissan Pickup
    How can i stop my AC belt from making noises when my AC is on
    The reason your belt is making a noise is either your belt is worn and needs replacing or the belt tension is out of adjustment and needs checking and adjusting.
    It is a good idea to replace it anyway specially if the belt has small cracks on the inside.
    Jan 13, 2010 | 2001 Nissan Maxima
    Kirby g4 belt replacement
    Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
    Dec 18, 2008 | Vacuums
    Dryers Logo
    52 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
