Question about Panasonic TH-42PX60U Television
Panasonic TH42PX60B has two vertical lines on left side of screen about 1 inch wide. One line is solid black while the other is white snowy.
    Brigadier General:
  • 8,909 Answers
You have an "Up Scaling" problem and a new screen will sort that out.
Posted on Oct 16, 2010
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Vertical line down the screen about 2 inches thick
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPING THIS WILL HELP TO SOLVE THE PROBLEM....
Aug 06, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Panasonic TH-42PX60U Television Logo
489 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
