Question about Vacuums
Holmes 8 in. Stand Fan - HTF3609A-BU manual - Vacuums
The red bar in the back of the vacuum keeps popping out of its groove how to get it back in without using brute force in which it may break. I also need to know how to take out the bar for cleaning
Hi, it's Allan from Dyson.
I have two videos for you which should help with this.
Relating to the brush bar, please have a look at this vid: http://www.dyson.co.uk/support/dc25_new/dc25-multi-floor-bu/how-to-use-your-dyson-vacuum/how-to-remove-a-blockage-from-the-brushbar/unblock-cleanerhead-video
In terms of the stabiliser pedal; this can potentially be an easy fix but if the problem appears different to that demonstrated in the video, it would be worth contacting us directly.
http://www.dyson.co.uk/support/dc25_new/dc25-multi-floor-bu/my-machine-is-not-working/will-not-stand-upright-1
If you'd like some further advice from our experts please feel free to give us a call - our contact numbers are: 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 26, 2015 | Dyson DC25 Vacuum
Oreck BU 10010 air passage blocked
If the clog is not at the nozzle just behind the roller brush you may need to disconnect the hose and clean it out. If you are careful not to puncture the hose try a coat hanger.
Nov 14, 2013 | Oreck Touch Bagless Upright Vacuum,...
Xl2600hhvacuum won't stand alone anymore, what is broken, is it a spring or some kind of catch missing
The detent that is mounted to the inside of the base cover is not working either because the screw holding has broken off or it is worn out. You could also have a worn out fan housing since that is what the detent catches to make it stand up. If the screw is broken off the only way to repair it is to replace the housing. Hope this helps.
Jul 15, 2013 | Oreck XL2600HH Upright Vacuum Cleaner...
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
I'm trying to locate a user's manual for a Holmes Comfort Triple Ceramic Tower heater (model # HCH6150)
Contact the MFG. of said unit. They will send you a link for a PDF file to view for your unit. :-)
Nov 06, 2010 | Vacuums
This fan is the Aloha Breeze 16inch Vintage Stand Fan made in March of 2010. Serial# 02299 model # 46052(46051) purchase order # 2082395186 UPC # 759590460526 it is the heavy chrome model. We have...
You are still in the warrranty period of one year and it is most adviceable not to tamper it so as to lose the priviledge.
So please get in touch immediatley with your dealer.
Only If there is no help do you need to open the base and check the leads from plug to the motor for continuity. if voltage is present then motor may be faulty.
Sep 14, 2010 | Vacuums
Electrolux Oxygen Remote Control Z5654 Vacuum Cleaner
Check your hose for obstruction. That might be the problem. If not, you will probably need service.
Jan 02, 2008 | Electrolux Z5935 Bagged Canister Vacuum
Vacuums Logo
104 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
