Question about NEC Electra Elite DTU 16D-2 Corded Phone
NEC Phone Reprogramming
How do you program the phone to a new phone jack?
Turn Set Relocation ON - Feature 84 and just move it.
If you are swapping phone locations:
  • Turn Set Relocation ON - Feature 84 then
  • From the phone being moved, press Speaker 61
  • Enter the swap extension
  • Enter password when prompted (probably 10 zeros)
Confirmation should appear on LED and you should hear a beep.
Posted on Oct 02, 2008
I have a NEC DTH-8D-1 Corded phone. I moved my desk and plugged the phone in at a different phone line port and the screen now reads "Initialize." What is it asking for? How do I set up my phone at th
Your extension is hardwired to 1 jack, if you plug in somewhere else you'll be lucky if the jack is active with another extension. Someone needs to re-wire your extension in the phone room to your new jack. If it won't activate but says Initialize, then that jack probably has a live fax line or analog extension, but not a digital line that works on your phone.
Sep 02, 2014 | NEC DTH-8D-1 Corded Phone
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
I HAVE A TELEPHONE SYSTEM WITH ONE PHONE NUMBER, BUT 25 EXTENSIONS. 23 OF THEM GETS A DIAL TONE, BUT TWO OF THEM DON'T. I DID TRY TO REPLACE THE PHONE JACK WITH A NEW PHONE JACK THAT I BOUGHT FROM...
A lot of questions need to be answered. But for starters, the other two phones probably do not have the line programmed into them. If these two phones light up...have any other working features then it's not the phones or jacks it's the programming. All phone systems have "line assignment"/ "line access" programming.
What make and model of system do you have?
P.S. On a separate topic, you should definitely have more than one line in your system for that many telephones.
Jan 30, 2010 | NEC DS1000 66-Block with AMP connector...
No dial tone on a nec dtu
The NEC phone is probably a business multi-line digital phone, requiring a phone 'back-end' system. Will not work on an analog 'home' phone line.
Feb 16, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Office NEC phone to be used at Home
This phone is a proprietory digital phone that only works with a KSU. You would need an IPK or Elite phone system to make it work. You would also need to program it. This is a business office system and that phone will not work unless it is plugged into the system.
Feb 05, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
"NEC DTU-16D-2" Need it to ring!
Woo Hoo! I figured this one out on my own!
However...WARNING! I wouldn't recommend doing this unless you are technically savvy, as one wrong move could totally mess up all of your phones!!!
I searched and downloaded the Programming Manual from here: http://www.nec.co.th/html/download/Manual/Programming.pdf.
This manual will not only tell you how to fix this issue, but how to pretty much fix/change all programming for the NEC Electra Elite DTU-16D-2 phones.
I have also searched and downloaded the Feature Manual from here: http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Happy Programming! =)
KayCee
Dec 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
How do I program my NEC IP2AT telephone system.
buy a phone that has an answering machine built in .PROBLEM SOLVED . you just plug in to elec and the phone jack
Sep 30, 2017 | Lands Phones
Headset on DTU 8D-2 corded phone
If you are using the headset jack on the phone, a headset key needs to be programmed on the the phone. You can do this in program mode and make a line key a headset key. Otherwise you must connect it through the handset. ldtsnj.com
Aug 26, 2008 | NEC DTU 8D-2 Corded Phone
Reconnect phone jack wire
Put the blue wire back on the red wire from the jack.
Mar 27, 2008 | NEC Dterm DTP 16D-1 Corded Phone
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
315 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
