Question about Dryers
All lights are on press start hear click and nothing happens
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 17, 2010
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
Where i can find elecrical wiring diagram
When you try to start the bike, does anything happen? Noises? Clicks? Or is it silent and nothing happens? If you hear a click or it try's to start but doesn't turn over. If nothing at all happens when you hit the start switch then you most likely have an electrical issue, versus if you hear the starter click or try to start to bike, then that would mean a mechanical issue.
May 14, 2014 | 2008 Peugeot Geopolis 400
I am getting either an E6E 0r EbE code on my affinity washer . I hear the relays clicking but nothing happens .
Hello chuckthom980 - Typically EBE indicates that there is an issue with the console control. Contact a professional to have the main control board replace.
Sep 30, 2012 | Frigidaire GLTF2940ES Front Load Washer
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
The dryer will not operate. you can press the buttons , all the lights come on, but as soon as you press start you hear a clicking sound and then nothing happens. I seems the dryer is on but nothing is...
unplug dryer, remove back panel, look for a white part with 2 connectors on the blower housing and remove one, using a continuity or ohm meter put across the leads and if you hear no sound or see no reading in meter replace that part. is the thermal fuse. this is the most common problem for that failure.
Feb 12, 2011 | Whirlpool GGX9868J Gas Dryer
When i try to start my dryer the sensing red light comes on and the dryer will not start...
That light should be telling you that your filter screen is full of lint, if that is not the case check the hose going all the way out for blockages.
Jun 14, 2010 | Whirlpool GEW9250 Electric Dryer
The sensing light comes on ,clicks, nothing happens
the sensing light comes on, I hear a click but nothing happens.
Dec 12, 2009 | Whirlpool GEW9200L Electric Dryer
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Dryers Logo
26 people viewed this question
Top Dryers Experts
