Question about SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW)
Does the 7" Smartparts SP70EWB need a memory card installed to turn on?
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
The slot marked SD/MMC/MS/xD is meant to be used for your regular memory card, such as the one you use in your camera. USB flash drives can be inserted into the USB port on the side of the frame.
To select from the various types of memory, press Exit until the memory devices are highlighted at the bottom of the screen, and then use the left and right arrow buttons to select the desired memory type. Press Enter to access the selected memory type.
QsMARTPARtS Technical Specifications Display (480x234) 7 inches TFT full-color Connecting High speed USB2.0 and 2.0 HOST computer Memory Flash memory: 128MB Power supply DC5V 2.0A-2.5A I AC ADAPTER Picture format JPEG Music format WMA Video format MOV / AVI, Motion-JPEG Memory card SD/MMC/MS/xD Language English, Spanish, French selection Control mode Remote control Supported Windows ME/2000/XPNista operating systems Warranty Smartparts, Inc. warrants its digital picture frames against manufacturing defects for a period of 90 days from date of purchase. For warranty claims, please visit our web site at www.smartpartsproducts.com or call 1-888-796-2749.
Smartparts Digital picture frame 7 User Manual
Nov 22, 2016 | Photography
Where can I find a memory card for my SP70EWB Digital Picture Frame
Hi, the cards that this unit can use is , SD , MMC, MS, XD. The most common one is the SD CARD that's the one that's in my own dig/pic/frame. You can buy them in camera shops or some diy shops or a larger store you should be able to pick one up just about anywhere just ask. Beware the micro sd card is to small on its own.
Jan 09, 2016 | Photography
Delete pictures from smartparts ps-74
Do not connect to the computer. Turn the frame on. Use the remote and I can't remember how I did it, maybe SETUP, but it gave me a drop down to delete all photos and I hit enter and it did it. Hope this helps a bit.
Jan 02, 2012 | SmartParts (1DPFSP01) Digital Picture...
Smartparts SPA802 - having problems with internal memory. Deleted photos from memory while it was plugged into Mac and now only have 888MB out of 2GB available even though there are no photos on it. How do...
Hi,First format the memory card.
Insert the memory card into the system and this will be displayed as the mass storage device in my computer . Right click over the removable disk and then click format . It will format the memory card .
Hope this helps .
Shane
Dec 21, 2011 | Cameras
Won't show pictures from compact disk memory card.
I removed my CF card from the picture frame and plugged it into my computer to see if it might be corrupted. It worked ok so I put it back in the Pic. frame and it worked ok their too ????
Dec 05, 2009 | SmartParts SPX8 Digital Picture Frame
How do I get the smartparts digital wood frame 7.0 to accept sd 4gb card? It just says no card when I insert it.
That frame cannot accept an SDHC 4GB memory card. Try something SD like a 2GB or 1GB and you should be fine. SDHC is not backwards compatible with all digital devices.
Oct 01, 2009 | SmartParts INC. digital frame. 7.0 in....
How to copy music files to my Smartparts
Are using a memory card. If yes, than go to "my computer" than click on drive that has memory card. (probably i: drive)
The Music file is probably is mp3. Pictures are DOC
Jun 02, 2009 | SmartParts SPX8 Digital Picture Frame
SmartParts SP1100B 11'' picture frame won't turn on
sounds like there was a power serge.  One of the suggestions would be to make sure you use the "safely Remove Hardware" tab on the tool bar.  The USB cable actually has power that goes through the line and can damage the flash memory in the picture frame.
your one hope would be to try another USB cable.
Mar 18, 2009 | Computers & Internet
Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
Jan 08, 2009 | SmartParts SPX8 Digital Picture Frame
I would like to know how to reset the settings on the SPX08 smartparts digital frame. It currently only turns on for approximately 5 seconds and then automatically turns off. Thanks.
I had the same problem with an SPX08E. It turned out that enabling the auto light sensor was the cause!
The way I fixed it was to remove all memory cards and attach the frame via USB to a PC. Then use windows explorer to delete all folders and files on the frame other than the smartpix installer MSI. Then remove the USB and power cycle the frame. It will come up at the main menu and you then have about 15 secs to navigate to the settings page, scroll down to the reset settings tab and reset all settings to defaults. You can then transfer any pictures you want back to internal memory.
Do not turn on the light sensor or you will have to do it all over again!
Dec 07, 2008 | SmartParts SPX8 Digital Picture Frame
SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW) Logo
113 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
