Question about Bosch Evolution 800 SHE58C02UC 24 in. Built-in Dishwasher
I would like to know if you have water left behind in the area of the drain is that normal? Should this be completely drained away?
    President:
  • 1,140 Answers
No, it's totally normal, The pump can't totally empty the washer and the hose because once it starts pumping air and water the air gives least resistance so the water remains in the hose. When the pump switches off gravity pulls a small amount of water back into the drain.
Your washer is 100% fine.
Posted on Oct 16, 2010
Asko fifteen eighty five dishwasher completes cycle, but the drain cup area still has water in it.
The drain cup normally has water in it after it drains. The pump runs it empty, but when it stops, some water runs back down from the drain hose, which you see in the drain cup. If there is water in the bottom of the tub, you may be having some siphoning coming back after draining. Check to make sure the drain hose has been routed up to the bottom of the countertop as per the installation instructions. That's what prevents siphoning, and its very important so it doesn't suck sewer water back in with the clean dishes!!
Jul 08, 2014 | Asko 24 in. D3250 Built-in Dishwasher
My Tecnik SD13J1 dishwasher (E-Nr SF6 TIE1 GB/21) had water in the bottom of it this morning. As it ran during the night I'm unsure whether the cycle had completed or not. I have removed the lower arm and...
The water usually comes from under the sink it is a 3/8 line from the hot side. it sounds like you have a bad valve or stuck float. check for a small round device in the left or right front corner and makes sure it has nothing under it and is pushed down
Jun 28, 2014 | Dishwashers
Water keeps on spilling out the back of the ARP 1000 ES Unit. I don't know how to empty the water container that must be located on the inside
The drain plug for draining accumulated water is located on the back of the unit's lower left side (as you're facing the back just to the left of the cord keeper. Unplug it, disconnect the exhaust hose and roll it to a drainage area. Unscrew the plug and let it drain. Securely replace the drain plug when draining is complete.
Hope this helped you.
Jun 09, 2011 | Sovereign ARP-1000E Air Conditioner
I cleared my outlet pump (Whirlpool AWM8000) area of coins, etc. Since as it was come up with error FP (drain fault). It drains during wash, but the last part of wash (last 5 min) it make a noise and error...
I would still suggest you go through the whole action all over again JUST to make sure that something hasn't been 'released' into the filter or the pump area. As the pump is managing to drain most of the water I wouldn't think that it is at fault. I would be interested to know if the 'error' is the same- 'FP'(?).
Here are my pre-typed complete (sorry!) guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 30, 2011 | Whirlpool AWM8000 Front Load Washer
Washing machine didnt complete the cycle and now wont drain the water away!
(try this!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to pursuade it to come out to play!
Hope the filter is the problem and good luck!
John C
Mar 18, 2011 | Washing Machines
Think some fluff or a sock is caught up somewhere as the water does not drain away and in order to get rid of the water I need to open the front flap and unscew the 'thing' behind it - how can I get in...
(The filter should be just inside the tube behind the 'thing' you unscrew! You should not need to get behind that area as the drain motor is immediately behind the filter and can be checked for debris- see my guidance notes!)
John C
Mar 18, 2011 | Hoover AAA140 Front Load Washer
MAH2400AWW ...WASHING MACHINE...NEED SOME INFO...WASHER STOPPED WITH I MINUTE LEFT IN THE CYCLE ..A BIT OF WATER LEFT WITHOUT DRAINING..CLICKS WHEN U TURN IT BACK ON BUT DOESNT START...MAKES A HISSING...
Because you say there is water still left I suspect either the drain filter or the drain pump.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
John C
Mar 04, 2011 | Maytag Washing Machines
AEG Favorit 8081 displays error F0 - there is a build up of dirty water which has not drained way. I syphoned all the water away and after a while the dishwasher started to work again - but then the...
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Sep 04, 2010 | AEG 24 in. Favorit 80800 Free-standing...
Leaves about 1/2 inch of water and doesn't completely drain
As long as the water that is left behind after the DW finishes is clean and there is no odor, your dishwasher is behaving normally and like 99% of all dishwashers. Clean water is left there to prevent the sump gasket from drying out.
Thanks for posting back what you end up finding, OK?
Aug 10, 2009 | Dishwashers
When turning on the A/C sometimes a white smoke looking vapor comes out. It goes away after a while though.
It's condensation. Moisture on the evaporator core. You may have a leak in your heater core or stopped drains in your ventilation system. To check for leak take to radiator shop have them pressure test system. To check for proper drain under car area below dash there are rubber hose outlets where the fresh air inlets drain any water, that comes into the cowl intake, dirt leaves etc. can stop up or restrict the drains and must be flushed. Easy way to tell run water into grill area under hood behind engine on cow area where you can see through and see wiper mechanics. This isn't smoke, smoke would stay, smell and take a while to go away and probably choke you. Hope this helps, please let me know. gl..dc
Jun 24, 2009 | 1997 Volkswagen Jetta
Bosch Evolution 800 SHE58C02UC 24 in. Built-in Dishwasher Logo
76 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
