Question about Sony KP-57WS500 57" Rear Projection Television
Crt lens is the a compatible/substitute lens I can use for the crt lens delta 260 #4-083-750-01 for my sony KP-57ws500
  • 77 Answers
Sounds like a conergence circuit failure, probably a couple of AMPs and a few discreet components. Probably 250-300 repair
Posted on Apr 21, 2007
  • 217 Answers
SOURCE: How to change CRT in Sony KP-57WS500
CRT is expensive!!! Try to shuffle the electronic parts driving the CRT tubes first, it has three sets of parts, all are the same in each color: red, green, blue. Sometimes cleaning the leads or metal parts of the circuits, specially the green region, will gonna solve the problem. Do it first, it wont gonna cost you a dime, just time. [:0)
Posted on Nov 12, 2007
  • 472 Answers
SOURCE: Replacing the blue crt - Help!
I know this isn't going to be what you want to hear (and I see the rating left for Jamie), but the tubes are extremely similar. The replacement of the tube is not easy in projection TV's.
You have special cooloing liquid that sits between the tube and the projection lens that sits on top. This is expensive stuff to buy, and not very easy to work with when refilling.
The tube is going to cost a packet due to the fact its the blue tube. Even in CRT projectors, the blue tube always goes way before the red or green. The manufactures know this, and will charge accordingly.
If you decide to do this then you have all that plus once it's all installed, you then have to have the correct service remote to do the calibration correctly.
I don't want to say it, and I know you don't want to hear it, but these TV's after they go in the current priced electronics market are not considered ecconomical to repair unless you dearly love the set.
The other bad news is now the blue has gone, the red and green will probably go in the next 12-18 months anyway.
I am not trying to talk you out of the repair, just trying to let you know what you are in for.
Posted on Apr 14, 2008
  • 10594 Answers
SOURCE: KP-57WS500 turning green or red and then off
Green and Red guns seems defective and requires replacement.
Both guns (CRTs) are no longer available so TV has no worth to repair.
Posted on Apr 19, 2009
  • 5138 Answers
SOURCE: I have a KP-57WS500 when I turn it on goes blue...
Type in Sony Blinking Codes, you will find alist that tells you want each one means.
Posted on Aug 06, 2009
How do you change a CRT red in a sony kp-57ws500
not a do it yourself job, what is wrong--too much blue or red or?
Apr 16, 2012 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 in. Rear Projection Television -
The red CRT needs replacement. You can get the Red CRT from they can also assist with installation information
How much would a picture tube $
You can get the complete CRT assembly for that model from they are listed under Projection Tubes CRT and your model uses the same as the WS510 models they are 115.00 and include the CRT, Lens and coolant chamber and the yokes and CRT drive board.
Aug 25, 2011 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
The screen on my Sony wide projection tv is turning blue after a few minutes. can you help? the model # is KP-57WS500
This is a typical bad CRT. The blue CRT part number is 8-733-647-25 but they are no longer available. It is not uncommon for this eventually to happen to the other CRT's as well. The only fix is to have a technician pull the defective CRT and have it sent to a company called VDC for rebuilding.
Nov 11, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony Problem
check for open resistor and defective capacitor.
check also the CRT socket
Jul 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
you need a new green CRT, sony has had some problems with the green and blue crts developing shorts . Let me know if you need further assistance.
May 09, 2008 | Sony KP-57WS500 57" Rear Projection...
Do either the red or the green crts come up at all?? If not the heaters in the blue crt could be bad - loading down the HV and the shutdown circuit turns the set off.. Only repair for that is to replace the blue crt, but I would have it tested first.. In the shop here we use a B&K467 to test for shorts and emission leaks but that's old school.. B&K has since come out with far superior crt tester/rejuvenators..
Dec 09, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
65 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
