Question about Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black
I cant get my temperture controll buttons to raise thre temperture
  • 132 Answers
Could be a problem with your thermastat ,shut it down for a while all the way then turn it on and see if that helps, only turn your unit up in small increments till you reach the desired temp.
Posted on Oct 16, 2010
Is there a manual volume button on the tv???? I dont have a remote controll, and cant raise the volume..
On the MX 3000 I don't believe there is a manual volume control. Sorry. Can you source a remote? A universal remote such as 3 in 1, may work.
Nov 27, 2014 | Televison & Video
2003 Lincoln Navigator, I cleaned my center console panel (AC/Heater control knobs) because of sticking buttons now the buttons (Auto, Off, Dual, etc) does turn on or off AC/Heat, nor does the display...
shudnt hav done that-u caused corrosion--now u need to take um out and see if their salvagable--getta haynes manual or sec629-ur local library
Nov 20, 2013 | Lincoln Cars & Trucks
Dropped my remote on floor and now no buttons work
your batterys probably got loose inside the remote. take the battery cover off and push them back into place.
Jul 13, 2012 | Samsung TV Remote Control
Dishes are still wet...water doesn't seem to be heating
bad water temperture. run the machine after you run the hot water faucet. add and fill jet dry .close the door lower it then raise it repeat three times then refill keep doing this until the dispenser cant hold anymore liquid. you will see a big difference.
Mar 03, 2010 | Dishwashers
Changed batteries on my 04 2500 HD diesel pickup
if the heater vent door is not stuck then there should be a resetcombo with the buttons.
Oct 26, 2009 | 2002 Chevrolet Silverado 2500HD
My subzero 650 freezer is at -20 degrees and i cant get the temperature to change. it is too cold
adjust temperture control to a lower setting........temp control may be sticking,replace it
Aug 27, 2009 | Freezers
The car keeps coming up a code 23 on a 1999 chrysler 300 for the
Code 23= Blend door feedback control
On cars with automatic climate control: To enter diagnostic mode, set the temperature to 75F, press the the off button. Press Floor, Defrost\Floor, Front Defrost simutaneously for 3 seconds until the temperature display begins to flash.
On cars without automatic climate control, set the blower to any speed, turn the temperature control in between warm and cold. Press Floor, Defrost\Floor, and Front Defrost. All codes will flash via the Front Defrost button.
When the test is over all fault codes will be displayed (on cars without automatic climate control, they will be blinked out on the Front Defrost button).
Code Action
23 Blend door feedback control
24 ATC mode door feedback failure
25 Ambient temperture sensor failure
26 ATC in-car sensor
27 Sun sensor failure
31 ATC recirculate door stall failure
32 ATC blend door failure
33 ATC mode door stall failure
34 Engine temperture sense failure
35 Evap temperature sense failure
36 ATC head command failure
Mar 23, 2009 | 1999 Chrysler 300M
Setup correct but operations not so well (urc-3445)
Universal remote controls may not have codes for all functions of a device.
May 25, 2017 | One For All URC-3445 Remote Control
Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
79 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
