Question about Onkyo HT-SR800 System
Cutting off and stayin in Stand by mode
I just bought this thing a couple of days ago and I had the sound on it one 1 hr from watching TV. It immediately shut off and went into stand by mode.
I try to turn it back on and it shuts off within 10 seconds. What have I done wrong during the initial hook up.
Thanks
    New Friend:
  • 3 Answers
To me it sounds like you might have blown a channel(s). The speakers that you are using with unit, did they come with it? If not you need to check the ohms of the speakers. It looks like the Onkyo HT-SR800 can only handle a minimum of 8 ohms. If your unit is under warranty definately send it in for repair
Posted on May 10, 2013
Tv powers up but goes directly into stand by mode
An Electronic component has failed. Unless you can repair circuits, take it to a shop or friend who can. Consider cost of replacement. A few hundred will fix an old tv, a couple more and you have a whole new unit.
Nov 16, 2013 | LG 42PQ30 42 in. Plasma TV
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
Headphones keep going quiet.
I would return them and either get a new one from them or another manufacturer.
May 11, 2017 | Sennheiser RS 110 Consumer Headphones
EVERYTHING I WATCH IS MOVING FAST!!!
Darn, that sounds like a time machine!
Whatever it is, though, it's hardly related to the TV if it only shows during movie playback and not in live TV.
I'd look at your player,
May 14, 2010 | Vizio SV470M LCD TV
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
Cant get old watch to chime
Instructions are on the inside of the back cover: 1. short circuit AC and the battery clamp. 2. the hands will rotate once clockwise 3. in the chime mode, pull out the crown and set the hands to the 12:00 position 4. Return the crown to normal position, change to time mode and set the desired time
Jul 06, 2009 | Disney Lorus Rare Musical R2306AX Watch
Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Apr 01, 2009 | Fossil Digital Sport Hologram Display...
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 | Watches
Onkyo HT-SR800 System Logo
121 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
