Question about LG Televison & Video
LD LST-5402P Adaptor Box
I am having trouble timer recording live TV with the box. I have hooked up the box through the RCA on the AV1 section on the TV. Was this incorrect? I am getting good reception, and the rew, f/fwd and rec seems to be working, though I cannot check it as none of the coloured buttons are working (list (red), program list (green), timer record (yellow), mark (blue).
Please advise
5 Suggested Answers
2manynotes
SOURCE: timer record set
Make sure the clock is set. Since the clock must be set before the timer will work, be sure you have entered an accurate date, day of the week, and time (including AM or PM). And always check the clock after a power outage. Also, check that your videotape does not have the tab removed which protects against further recording.
Posted on Jun 25, 2007
SOURCE: LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Posted on Aug 02, 2007
  • 5 Answers
SOURCE: LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Posted on Jan 18, 2008
  • 78 Answers
SOURCE: TV wont come on
the picture tube is most likely not out. but there is a problem in the high voltage transformer part of the set( this is what fires up the picture tube). a problem like that can be just as expensive as a new picture tube. if it's not still in warranty it would be cost prohibitive to repair.
Posted on May 02, 2008
VOTIT
  • 2071 Answers
SOURCE: Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Posted on Jul 16, 2008
My manavox tv dvd/vhs unit is hooked up to a converter box. All I had to do was turn on the converter box and then the tv. It was working just fine untill I cut if off one day, instead of leaving it on...
  1. Try unplugging the converter box from the power, and RCA or Coax connector. Reconnect the power and RCA or Coax connector. Try turning it on.
  2. Look for a reset button. May be a small hole with a button inside, if you find one use a paperclip or similar to press it.
  3. Try the converter box with a different TV.
  4. If this doesn't fix the problem, replace the converter box.
Feb 22, 2011 | Philips Magnavox 20MC4304 20 in....
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
Hi my tv turns on but just shows a blue screen and the sensor light flashes red there is no picture or sound ive tried switching it of from the mains plug sky tv in and another dvd player but no good any...
try the av buttons on your remote, see if it switches to ur external box.
if that doesnt work, try a s-video (and rca audio cables) to scart adaptor (with those mensioned cables)
from the box, if that works, could be something to do with the scart?
or could be a av issue,
Jan 02, 2009 | Televison & Video
Memorex tv/dvd will not go off of input avi 1
I KEEP GETTING A BLACK BOX ON MY TV. I HAVE A SHARP MODEL #32RS400. ANY SUGGESTIONS?
Dec 22, 2008 | Televison & Video
Rca tv/vcr combo model T13208
Recording speed is the last item on the timer programming. SP or SLP. Some remotes have a button that will allow you to change the speed, when recording manually.
Sep 12, 2008 | RCA T13208 13 in. TV/VCR Combo
Record to vhs with converter box
I need to leave my TV on channel 3 and set the converter to the channel I want to record. When programming for future recording, it's always from channel 3, not the channel I want the converter displaying.
Jul 17, 2008 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Televison & Video Logo
77 people viewed this question
